Question about Sony Cybershot DSC-T200 Digital Camera
Sony DSC-T200 Flash will not turn on, only option is to turn it off, says there is no flash.
  • dsc-t200-fix Jul 13, 2008
    Be sure the camera is not in Burst mode.
  • 3 Answers
Try initialising the camera (settings menu) - the flash options came back on mine, and the flash worked again.
Posted on Jun 02, 2009
I have a sony DSC-T200 and the flash won't work. It doesn't even give me the option of turning it on. What do I do?
I had the same problem.
Touch "menu" then under the "rec mode" change from burst to NORMAL.
Then you can touch the flash icon and turn the flash on.
Jul 07, 2010 | Sony Cybershot DSC-T200 Digital Camera
My flash won't turn on! When I go to the flash icon to turn it on, the flash option isn't even there!
Mine was doing the same thing but I noticed (after playing around with it for a while) that I had the "REC Mode" on BURST and not NORMAL. When I set it back to NORMAL the FLASH options returned. Select MENU on the main display and the first option will look like a picture frame or multiple picture frames. You want it to look like the single picture frame for the FLASH option to be available.
Feb 22, 2010 | Sony Cybershot DSC-T200 Digital Camera
The flash on my camera wont work and I dont know if i need to turn it on or what
yes you do need to turn it on to take a flash pitcher, unless you have set it up in memery to come on if needed,
Nov 05, 2009 | Sony Cybershot DSC-T200 Digital Camera
Camera flash too bright
Hey,
You ve a four way navigation key Right..In that you ll have a symbol similar to a lightning bolt...press that to lower the flash intensity..or to have no flash at all..
please rate my suggestion..
Apr 15, 2009 | Sony Cybershot DSC-T200 Digital Camera
Flash off sign.
I had a similar problem, where the only option on the menu for the flash was off. I initialised the camera (reset everything), and the flash options have reappeared, and it now appears to work fine (initialise is in the settings menu from home).
Dec 31, 2008 | Sony Cybershot DSC-T200 Digital Camera
E.91:01
the flash board of the camera gets one fire ic damaged u remove the flash board jack ur camera will work ok without flash
Nov 19, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash stopped working
I had the same problem, "BBWS" found this "solution":
Turn the camera on as if to take photos (not to review photos).
Press "Home" (upper left corner)
Press the camera tab (bottom left-most tab)
Press "Scene Selection (SCN)"
Press "OK" at the "Select type of scene" prompt
However, I still don't have flash available in the PGM or AUTO modes, which tells me it is still broken.
Jul 13, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash
Flash circuit is bad in your camera and needs replacement. If you have basic knowledge of electronics, go ahead and if not, contact nearest Sony repair shop.
Jun 21, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash won't come on
You should have the dealer check the camera. The flash unit may be defective.
By default when a camera is new out of the box, it should work as full automatic with the flash.
Jerry G.
Apr 28, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash can not be turned on
I had the exact same problem as Dude2891 and it took me ages to work out what was wrong. The problem turned out to be that when I first got it and was playing with the menus, I managed to put it on burst mode, and in burst mode flash is automatically set to off. So you need to turn it on, press menu bottom left and scroll to REC mode (the first option) and then check that you're on Normal not Burst. That fixed it for me! See also Sony's tips at http://support.sony-europe.com/DIME/faq/faq.asp?l=en&c=DIME&sc=DSC&m=DSC-T200&f=mod_dsc_W_H_T
Hope that works guys, let me know how you get on.
Dec 16, 2007 | Sony Cybershot DSC-T200 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
269 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
