Question about Samsung AS18A6RB Air Conditioner
Samsung SH12YAB After power failure,the air condition was switched off.....
SAMSUNG SH12YAB
After power failure,the air condition was switched off.When the power was back on,the air condition was still off .It needs to be reprogrammed through the remote control.For that,I need a code to key in.Could you please send a code for this modell?
bobotfel
  • 236 Answers
SOURCE: Samsung AS-0914ER split system wall air conditioner
Here are different kind of unit with there manual button location, hope this may help.
Posted on Mar 05, 2008
  • 518 Answers
SOURCE: samsung air conditioner remote ruined--need new one
You're going to need the model number. It may be under the front cover.
Geno
Posted on Mar 10, 2008
SOURCE: remote control
THEY DID NOT SEND ME THE BOOK WITH REMOTE
Posted on Aug 04, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Need remote control code
0867 should do it
Posted on Jan 14, 2009
ltfrc
  • 227 Answers
SOURCE: Side by side Samsung TV's need remote control solution
If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
Posted on Feb 16, 2009
Samsung led ue32eh4000 wont tourn on
Could be an open internal fuse, power supply failure, or a defective power switch
Aug 25, 2016 | Samsung Televison & Video
I have a Samsung one ton ductless air conditioning unit. Unit turns on in cooling mode, but after 15 seconds system turns off.
It sounds like it is cycling on a 'low pressure' switch due to a loss of refrigerant. However there a number of sensor failures that could cause the same thing.
I'd suggest contacting a reputable service organization for service.
Oct 01, 2015 | Samsung Heating & Cooling
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
Why wont samsung air conditioning not respond after main switch of house was of
It's possible it has tripped a breaker. If it has the big square plug it may have also ttripped the GFCI built into the plug.
Oct 09, 2014 | Samsung Heating & Cooling
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
Samsung smh8165b won't power
The fuse is probably open, when this happens it usually indicates a secondary problem from a defective door switch, keypad control board failure to a inverter board issue.
May 31, 2012 | Samsung SMH8165B Microwave Oven
Samsung Plasma model ps-50p91fd red light flashing will not turn on can hear clicking as if going to switch on but nothing happens just switched off last night problem occured this morning
Hi:
First thing you should do is unplug the unit from the AC outlet and wait 5 minutes before pluging it back in. IF this does not solve your problem, then you should the unit serviced. The most common failure part in plasma's are the y-substain board and the power supply, have these check for shorted conditions.
Sep 09, 2011 | Samsung Televison & Video
Samsung t220 wont power. up no power button?
Here are the user and owner manuals, the power switch is at the bottom right of the monitor, it is touch sensitive type,
http://www.samsung.com/ca/consumer/office/monitors/lcd/LS22TDNSUV/ZA/index.idx?pagetype=prd_detail&tab=support
You may have power supply failure.
Mar 19, 2010 | Samsung T220HD LCD Monitor
The went out in my condo and I have 3 samsung air
Unplug all the units, and wait for about a minute and plug it back. This is to reset all the units back to the
original condition. Hope this works.
Jan 05, 2010 | Heating & Cooling
A/C Samsung spilt ( working fine then after 8 hours gives warm air)
It sounds to me like your fan cycling switch is sticking while the unit is cycling off (fans). When this happens your condenser does not have the ability to remove the heat from the refrigerant which in turn causes the compressor to load heavy. This creates a very high pressure condition on the high side. When this happens go outside and see if the condenser fans are running.
Hope this helps You
please rate me
Jul 18, 2008 | Samsung AS18A6RB Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
303 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
