Question about Samsung CLX 3160fn All-In-One Printer
Scanner locked I see the lock and unlock markings under the glas but how do you get to it? Do you have to tear it open??  I couldn't find anyway else to get to it?  Thanks, OR
  • Anonymous Jul 24, 2008
    scanner is not working. When I switch it on is ok. But when I insert the U.S.B to scan it is indicating Scanner locked. How can I unlock it. Please I need assisatance. Send me through my email bonnieafrica@yahoo.com
There is a green lever on top of the output tray. Push it back to lock and pull it toward you to unlock the scanner. Hope this helps!
Posted on Aug 06, 2008
Code 2, 189,0
All scanners come with the scanning head locked to prevent damage to it during shipping. On the back of the scanner, where the power cord and wires connect, there will be a sliding switch, sometimes a turning type lock, with two positions, one with the icon of a closed [so locked] padlock and the other with the icon of a open [so unlocked] padlock. Every scanner I have bought describes this lock in the setup manual.
Oct 17, 2014 | Canon CanoScan 9000F Mark II Color Image...
How to unlock scnner
There is usually what looks like a large screw head either under the top cover that you lift to insert an original onto the glass, or somewhere in that area. It will have two symbols, a closed lock and an open lock, or better yet, the words "lock" and "unlock." This keeps the carriage from bouncing around while the scanner is being moved. Use a quarter or a screwdriver to rotate the screw head to the unlock position. Unless you are traveling with the scanner, leave it unlocked.
Oct 03, 2012 | Umax Astra 4000U Flatbed Scanner
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
Mon imprimente pixma mp810 donne un code erreur 5020 et demande de deverouiller le scaner
This correction is listed on the Canon website. Lock Switch Make sure to unlock the scanning unit before turning the machine on.
  1. Lift the document cover open.
  2. Slide the scanner lock switch to the release mark.
    Caution : Make sure to unlock the Scanning Unit (Printer Cover) before turning the machine on.Before transporting the machine, always lock the Scanning Unit (Printer Cover) by moving the Scanner Lock Switch towards the lock mark.
  3. Close the document cover.
  4. Press to turn off the machine.
  5. Wait approximately 5 seconds then press to power back on the printer.
Mar 27, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
My scanner is asking me to unlock the hardware, but the switch is already unlocked what do i do???
Some scanner models have a physical lock mechanism under them for use during transport that stops the scan head from sliding around. Check under your scanner if it has one and slide it along to the open/unlock position if it does.
Mar 07, 2010 | Xerox One Touch 2400 Flatbed Scanner
Scanner locked?
On some models there is a transport latch to lock the scanner. Look under the scanner (where the copy comes out) and you will see a green slide. Look down thgrough the scanner glass and you will see a lock/unlock symbol.
May 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Jul 14, 2008 | Lexmark X340n All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
