SOURCE: DELL POWER SUPPLY TYPE PS-5201-5D REV.F
230 Watts.
Here are specs and replacement:
230W ATX Power Supply - PS-5201-5D - HP-233SNF ...You can also replace it with a compatible 300 W psu.
SOURCE: HOW TO CHECK IF THE POWER UNIT IS WORKING...? DELL PS-5201-5D
short green & black wire...if smps fan is working then ur smps s fine....& make sure u disc all smps cables from all preperials like cd rom hardisk etc
SOURCE: what is the p7 connector on a atx-1956-d for?
This is not a problem, and as it sounds, is not used in your system.
Some video cards have such huge processing power that they need thier own supply, as it would draw too much current from the motherboard otherwise. Below is a web site which reinforces this information, and gives an explanation of each connector.
http://www.affordablesurplus.com/bestec-atx-1956d-power-supply.asp
Or do I not understand you. Do you have one less, or one too many?
SOURCE: Pinout for dell power supply with model number Ep071298
There are no wires, it's a big hot-swap plug.
