Question about Cameras
My camera wont work comes up leans error - Cameras
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started having trouble.
Here is how to fix it.
Before trying any of the suggestions, make sure your Camera has fresh batteries in it.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
I hope this helped you. Thank You for using FixYa
Posted on Jan 04, 2011
  • 613 Answers
Lens error. This can be cheap or expensive. Try blowing it out with compressed air while pressing the buttons. Do not force it. You can also try the usb adapter that came with it and plug into a computer and hold the snap picture button. These are the cheap solutions. Expensive is to force it and break it or take to a camera shop. I suggest the latter as it can be fixed.
SOURCE:
When I turn on my camera it says lens error and than immediately shuts down.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 30, 2011 | Casio EXILIM EX-ZS5 Digital Camera
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
Camera says lens error, restart camera It is a Power Shot SX100IS
the leans in your camera has been damaged.so you want to change the leans.
Aug 28, 2009 | Cameras
I use w210 Sony Cybershot! Error E:91:01.
I use w210 Sony Cybershot! I was taking pictures out in the sun, when I saw smoke coming out the camera and the camera become very hot. I also saw that I was using the camera bymistakely in the twilight mode out in the sun. And since then I tried intitializing it but the Error E:91:01 and flash symbol wont stop blinking. And flash Seems to have stopped working. Please help me to solve this problem
Jul 14, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Camera leans error help.
hi,
your camera needs a service. because some dust particals gose inside the camera leans and effect the alignment of your camera.
Thanks for using FixYa.
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix camera lense wont retract :(
You can send the camera directly back to Nikon for an estimate. If you bring it to the store they will add on the cost for their time. Call Nikon to find their nearest service center.
For any problems on these cameras, they will need factory service.
You may find that servicing the camera will be near to the cost of replacing it, unless it is a very expensive model.
Jerry G.
Sep 01, 2008 | Nikon Coolpix L1 Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
