Question about Toshiba 50HX81 50" Rear Projection Television
Squiggly lines when i power the unit up the entire picture is real squiggly and after about 10min. the picture is fine but the last couple weeks the problem is getting worse and worse and not completely going away any more. any ideas would be greatly appreciated.
  • 1 more comment
  • tactician Jul 29, 2008
    i believe i also have the same exact problem dquiggles used to go away, but now it is basically unviewable picture it has gottten so bad, has anyone yet received an answer to this so i can finally fix it?
  • victoretta Sep 09, 2008
    The picture from the primary tuner suffers from squiggly lines during the initial warm-up period which gets longer and longer. When viewing th same channel with split screen, the second picture is f9ne.
  • rlmfly Jan 02, 2009
    How do i know witch board is the hyper board inside the set.I have not opened it up yet.
  • 51 Answers
I fixed alot of those sets already with the same problem there are about 10 capacitors in the hyper board that needs to be repalaced.Some companies like PTS will sell a rebuild hyper board and it would be easier to fix it that way than trying to rebuild it yourself depending on your skills.
Posted on Jul 10, 2008
Squiggly lines on copies
THE CARTRIDGE PORES ARE PARTIALLY BLOCKED USE FORCED COMPRESSED AIR TO OPEN OR BLEED THE PORES AND THEY WILL WORK FINE
Jul 19, 2013 | Copystar CS-1620 Copier
Sony tv mfm ht75w tv doesn't stay on, works for 10min sometimes,, other times only sec. i opened it all the caps seem ok, any ideas
Please clarify whether the entire tv powers off or only the screen turns off and you can hear the sound so that we can continue with the diagnosis. Sony LCDs are notorious for backlight inverter failures.
May 06, 2010 | Televison & Video
Multiple squiggly lines fill the LCD screen, after
Sounds to me like your inverter has gone bad. Typically it's situated just below your LCD. To get to it you will have to take out the screws around the LCD bezel. It's a long, skinny circuit board that the LCD plugs into. You can usually find a replacement on Ebay. Just be sure that you're ordering the correct part, otherwise it may not fit or work properly. I've also had times when the entire LCD was going bad and the display was full of squiggly lines. It's hard to say which one is the cause. I would try replacing the inverter first. That part is usually much cheaper than the LCD is.
Apr 10, 2010 | Toshiba Satellite M60 Notebook
04 crf450.hard start when cold(25deg).kick for 10min.once it
1. First thing is when was the last time you had your valves adjusted
2. On cold start up twist about 15 times on your throttle, as you do that the accelerator pump in carb will shot gas in cylinder, I have a 2003 yx426 & 2005 yz450 have to do to both of them when cold out to get started
Feb 07, 2010 | 2005 Honda CRF 450 R
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Unplayable disc? 4 correct discs tried.
try unplugging the unit for a short while....10min +
plug it back in.... it just might work... fingers xed
Dec 05, 2009 | Televison & Video
My 31GT740 tv's picture is taking up to 5 minutes to come on...
There is possibly a loose solder joint in the horizontal drive circuit. There is a little coupling coil just before the horizontal output that will get loose. This should not be real expensive to have repaired.
Oct 20, 2009 | GE 31GT740 31" TV
Picture has gone bad on my 70 in Misubishi
My recommendation is have a svc co. look at it. That model was noted for multiple electrolytic caps being bad and also solder joints. As long as the picture was good prior to your problem then I would say it's worth repairing. I worked on the same model for 3hrs to take care of all the problems and preventive maintenance.
Mar 22, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Black lines
HAD THE SAME THING HAPPEN TO A FIJI "FINE PIX" A-500.... CALLED THE AUTH. REPAIR CENTER AND UNLESS YOUR WARRANTY IS STILL IN EFFECT , THE COST ESTIMATE JUST TO FIND OUT WHAT THE PROBLEM IS WILL RUN YOU ABOUT 75 TO 80% THE PRICE TO BUY A NEW UNIT..... ON MY THIRD A-500 IN THREE YEARS.....HOPE THIS IS OF SOME HELP..
Apr 27, 2008 | Fuji FinePix E550 Digital Camera
Weird lines when Playstation turns on
are you getting proper power up ...sound etc...no picture??
Dec 20, 2007 | Sony PlayStation® 3 (60 GB) Console
Toshiba 50HX81 50" Rear Projection Television Logo
272 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
