Question about HP Pavilion Notebook
Hp Pavilion monitor black
I start my laptop but i get nothing but the blue lights on the keyboard and nothing else. Everything is black on the monitor and get no sound. Maybe i hit a key or something that i caused this to happen i don't know. Can someone help me please? thank you
  • Sunny30 Jul 10, 2008
    Hi topgun, nope i already tried that, the problem still persists and i don't have the manual for my laptop. I have no idea where it is. Can you tell me how to get it off the hyp mode? Cause it sure sounds like it is the issue. Thanks Sunny
  • Anonymous Oct 02, 2008
    I have the same problem, and when I powered down fully (I even took out the powercord and removed the battery before trying to restart) the same thing happened when I restarted it. The screen stayed black but all the lights on the laptop are on iincluding the lights on the inputs for the LAN connection and the SD/XD card. The light in the CD/DVD drive is blinking too.
    Problem Solver:
  • 8 Answers
Perhaps you have accidently put it into suspend or hibernate mode when you last used it and it did not power down fully. If you check the manual about one or both of these settings it may help failing this keep you finger on the power button for at least 7 seconds to do a complete power down and then restart.
Good luck and hope this works
Posted on Jul 09, 2008
  • topgunner Jul 10, 2008
    Hi Sunny30,
    let me have the full model details and I will see what I can do.
Black screen on hp touchsmart 310-1020
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 11, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
I have a laptop dv9500. The monitor is black and no bios or any sign of picture,nothing is on the screen just faint blue light. where is the problem?
The HP Pavilion dv9500 is one of the Pavilion dv9000 series of Notebook PC's.
This is the problem, and the possible solution,
(TIP: I would use a Heat Gun instead of a torch)
Dec 02, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Oct 20, 2009 | Compaq Laptop Keyboard for HP Pavilion...
HP Pavilion laptop screen has gone black/blank
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Blank/Black Laptop screen on HP DV-6000 notebook
Please have a look at this article and consider updating the BIOS: click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 03, 2009 | HP Pavilion dv6000t Notebook
HP Pavillion 9925nr LCP monitor turns black
Check screen brightness.
On keyboard is normally activated by combined FN + Fx keys (F9 or F10).
Check your keytops and/or your user manual.
Using this feature you should be able to restore a standard contrast on your screen.
If it isn't working the only alternative is external monitor.
Feb 16, 2009 | HP Pavilion dv9000z Notebook
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
