Open
"Start" and click "All Programs." Select "Windows Update." Type in your
account password if the operating system prompts you for it.
Click
the "Check For Updates" link. Select "View Available Updates" and check
to see if any drivers are listed for your laptop. Click the specific
driver you want to update.
Click
"Install." Restart the laptop after the installation finishes and see
if the driver problem is resolved. Return to the "Start" menu and click
"Control Panel" if the problem persists.
Select "System and Maintenance." Click the "Update Device Driver" link underneath the "Device Manager" heading.
Find
the specific device that isn't working properly in the list of
available devices. Right-click the device and choose "Update Device
Driver."
Windows XP
Right-click the "My Computer" icon on the desktop. Click "Manage," then select "Device Manager."
Scroll through the list of hardware devices being used by your laptop. Find the specific device that is having a driver problem.
Right-click the name of the device and choose "Properties." Navigate to the "Driver" tab.
Click "Update Driver." Select "OK" to repair the driver problem.
Hello Imc420, there are (4) four different ways to connect to the Internet. 1) To start, click on the "Start" button, in the (right "start menu" pane), select the Control Panel 'shortcut'once the nextwindow open; scroll to find, Network and Internet, click on it to open.Next, select to open the "Internet Options."To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button, and follow all the instruction carefully. 2)From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open;"this will start the setup and connection process." 3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present" Option is available?" select to open, and click on the Connectivity Doctor,follow all instructions thereafter. (4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories, select to open: if you have the [Windows Mobility Center], open the program; there will be a Wireless Network 'Turn-on and Off Switch" Important"Always! Click Apply, Ok, and Restart the computer after making changes to the computer." "Did this solution help?" If so, "helpful Rating Feedback appreciated, thanks paul7of9."
Follow this steps on how to scan docs/files > open the top cover, load original document facedown on the scanner glass. >close the top cover to avoid dark edges on the scanned docs > Make sure printer is connected to computer and both printer and computer is on. > From the printer control panel press scan > Follow the instructions in computer screen. If u are using Windows > Repeat 1 and 2 on top instructions, Do one of the following; > In windows vista click select all programs and then select the printer program folder from lists. > In Windows XP click start Programs or all programs and then select the printer program folder from the list. > Click Lexmark Productivity Studio > On the main screen click scan > follow the instructions on the screen..
Open the top cover, and then load an original document facedown on the scanner glass. Close the top cover to avoid dark edges on the scanned image. Do one of the following: • In Windows Vista, click All Programs, and then select the printer program folder from the list. • In Windows XP, click Start Programs or All Programs, and then select the printer program folder from the list. Click Lexmark Productivity Studio. On the main screen, click Scan. Follow the instructions on the screen.
