My ref. is not working properly
i remove the inside frezzer panel and notice that the interior blower fan in inop i check the connection they look ok . possible bad fan motor?
or any relay?
please help
Instead of folling with the wiring, make sure the fan is just rusted into place...give it a push by hand and electric power should do the rest. THE FAN HAS NO TORQUE AT REST.
cski
There may be a door switch which turns the blower motor off when door is open. If this fan switch is bad it would cut power to the motor.
Refrigerator door switch appears to be ok, on both door .
The interior lights are working fine, that means that switches are ok
Am I right ?
thank for taking your time
when i removed the back panel
i hard wire the fan motor to make it work (added ground to the motor) and and the refrigarator start working fine
but the motor stays on at all the time.
this time i removed the wire to test the swithch
for some reson the fan is working fine
without the added wire. now i remove the door switch and the fan still working
i think that the door switch is not the one turn on and off the fan
am i right? my refrigerator is working fine at this time im going to see how long it last if you have any other suggestion please let me know. thanks
