Sharp tv i have a sharp tv that started turning off after 15 to 20 minutes. let it set a while and it would come back on. Now, it has gone off and will not come on at all. It is connected to direct tv, which works fine on other tv's
  • sclark1941 Jul 16, 2008
    jeremiah. i certainly appreciate your suggestion. also i will have it checked out.
    thanks again
    s
  • 417 Answers
sounds like a heat dissipation problem, or was, I take my covers off and airdust my sets every 6mths when I do my computers Sharp televisions are extremely good sets, my mom and dads sharp 10 inch color tv with vacuum tubes worked for 40 years without a hitch. I would take yours in to see how much its going to be. be careful if you take the cover off , theres high voltage present even unplugged via the heavy single red or yellow wire going to the tube.
sorry
J
Posted on Jul 11, 2008
We have a brown out and the cable and tv were on the cable came back on but my tv won't power on
Unplug the tv for a few minutes, if it won't turn on after that either a fuse or the power supply has gone bad.
Jul 27, 2015 | Sharp Televison & Video
Can't turn tv on stuck scanning channels
Something simple to try: remove the set from power and any box etc in line to it for several minutes and then power things back, cannot hurt and may help
Dec 23, 2012 | Sharp Televison & Video
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Lamp problem?
your picture processor is broken. we have the same tv, after 1 year problem started. we got a tv tech out and he looked at it and said it would cost $1800 to fix and this is after we bought a $400 bulb from sharp. this problem is in many of the same tv's of this exact model as we've invstigated and sharp is unwilling to help. there should be a classaction suit or recall for this exact tv.do not buy bulb , it will not work
Aug 18, 2007 | Sharp 56DR650 56" Rear Projection HDTV
TV distorted colors
It needs to be demagnetize but the tv has it's own demagnetizer and it does it when you turn the set on,you need to unplug the set from the wall for about 15 minutes and then plug it back in and turn it on and the splahes should go away,if you have placed speakers on top of the set or in its sides remove them because they will cause this problem or if you have move the tv while it was on or the set was dropped.Let us know what you find.
Oct 04, 2006 | Sharp 27C-240 27" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
