Question about Xerox WorkCentre M15ix All-In-One Laser Printer
Scanner doesn't scan
When I try to scan something the screen says "connecting" and doesn't do anything
    President:
  • 2,072 Answers
Start by changing the USB speed...
Two USB modes are available: Fast, which is the default, and Slow. Poor USB operation may be experienced in the Fast mode, in which case the Slow mode should be used to improve performance.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Down] arrow button until 'System Setup' is selected, and then press the [Enter] button.
  3. Press the [Down] arrow button until 'USB mode' is selected, and then press the [Left] or [Right] arrow button to select either [Fast] or [Slow].
  4. Press the [Enter] button twice.
  5. Press the [Menu / Exit] button, and then press the [Stop] button to return to the Standby mode.
Posted on Jul 10, 2008
  • Rick Kasper Jul 10, 2008
    If you continue to have problems. Look at the information on the Xerox.com website. I will tell you the steps as best I know how to get there.
    1. Go to www.Xerox.com.
    2 Once there click on support and drivers on the top of the home page.
    3. You will see a search box appear, type in M15i and click search.
    4. Once you get to the M15 support page, simply type in scan, several topics will appear, I think it's about 15 topics. I do believe if after you try changing your USB speed, if that doesn't resolve your problem, one of those topics listed on the Xerox website will resolve your issue. Easier to look there in their detailed steps then sitting here trying to "splain" them to you.
    Hope this helps. Let me know please.
Fi-6130z continueously scans. It doesn recognize when there is no paper to be scanned
Your scanner went crazy. If you don't want to take it to repair, just disconnet it after you've finised scanning
Oct 09, 2014 | Fujitsu fi-6130z - Document scanner -...
I tried to connect my Canoscan lide 90: when I try to scan: my computer doesn t seem to connect to the scanner: try the cable, connection and turn the scanner on. The connections seem to work... how do I...
Hi ,
The driver is probably missing . You can download and install it from here :http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide90#DriversAndSoftware
Best regards .
Aug 04, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
If it is your first time using your printer, then you need to install the driver for it to work.
If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:
1. Connection error
2. Driver problem
First thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly.
If rebooting your computer and printer won't fix the problem. Here are the things that you can do.
1. Connection error:
a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b.
b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process.
If all steps above don't work, then you need to check the driver.
Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work.
If it doesn't, please reply to this thread.
Thank you for using fixya.com
Carlo Adrian
Nov 14, 2012 | Dell Photo 926 All-in-One Printer
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
I am trying to scan a document, and have scanned it to "word" and to "email" and to Internet explorer, on the scan choices, but can't find it anywhere on my computer. Plus, when it...
A quick to fix to most communication problem is to reboot your system. Disconnect the printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again. When scanning using the scanner glass, the scanner light will move across the glass to scan your original document. The printer will then process the image and sends it to your preferred application on your computer.
Jun 14, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I am trying to scan with my HP printer and the power botton flashes and the printer doesn't do anything
Try opening a scanning program and scanning from there.
Get Picassa if you don't have it, and try scanning in there. Open the Import tab, then change the Import From to select your scanner.
May 05, 2011 | HP Deskjet F2210 InkJet Printer
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My brother won't scan
Never mind. I went to http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/model_top/colormfc/mfc210c_all.html?reg=eu&c=eu_ot&lang=en&prod=mfc210c_all and downloaded a program called "Brother Control Center"(version 2.4.2.) and now my scanner works just splendidly!
Jan 18, 2009 | Brother MFC 210C All-In-One InkJet Printer
Help !! ,Microtek scanmaaker 3840 problem
maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
Feb 24, 2008 | Microtek scanmaker 3840
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Xerox WorkCentre M15ix All-In-One Laser Printer Logo
95 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
