Question about Plextor PX-708A DVD±RW Burner
The Plextor PX810SA arrived today - no instructions, no manual - there is a strange 3 foot red cable with small plugins on both ends... 2 'sort-of' labels: "ROHS" & "CROSS OVER" - not a clue as to any of this. I suppose the "SA" stands for SATA - my hard drives are SATA's - so?
    Master:
  • 848 Answers
The cable that comes with this product is SATA cable and you have to connect to sata port
Posted on Jul 09, 2008
  • 1,879 Answers
Greetings,
The cable that came with the product is a SATA Cable and you have to connect the Plextor to a SATA connection just like your Hard Drives.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • 13,433 Answers
Yes thats SATA, sata supports hard drives and cd/Dvd drives also, you will need to connect it to a sata port or buy another sata controller for pci.
  • 4 more comments
  • Ekse Jul 09, 2008
    my burner also goes to sata, the installation is pretty simple,
    insert the dvd drive into the pc case, screw it in. and connect the cables.
  • Ekse Jul 09, 2008
    if your out of sata ports you can get a pci card like this
    http://www.newegg.com/Product/Product.as...
  • Ekse Jul 10, 2008
    sata power on the left sata data on the right.
    if you don't have the power connector you need a converter.
  • Ekse Jul 10, 2008
  • Ekse Jul 10, 2008
    let me know if you need further support or anything else..
    -Reply / comment Sends me a message
    -Request more assistance / reposting the problem rejects my assistance.
  • Ekse Jul 10, 2008
    Thanks,
    Ekse
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Tip
IPhone 3G instructions - disassembly
Got this great instructions from - www.rapidrepair.com.
Tools required:
Small Phillips Screw Driver
Small Flathead or exacto razor
Safe Open Tool
Remove the sim tray, use the included sim card removal tool (or a paper clip if you've lost the tool.)
Holding your device on end you will notice two small screws on either side of the dock. These screws must be removed in order to open the case.
Insert a small thin tool between the chrome ring and front panel glass directly above one of the screw holes. You will need to exert a small amount of pressure to separate the display from the back panel.
Lift the panel up from the dock end being careful not to tear or break any ribbons connected near the other end.
Unplug ribbons 1 and 2 by lifting them from the main board. Under ribbon 2 you will need to find and unclip ribbon 3, then carefully remove the display assembly.
Remove the seven screws circled in red. Note: One screw is located under the DO NOT REMOVE sticker.
Unplug ribbon 4.
Lift the mother board out taking note of the camera which is still connected to the underside of the board. You will need to unplug the ribbon circled in red.
Place the mother board to the side.
Use the attached tab to pull up on the battery, there is a mild adhesive on the back side, so it will take a bit of force.
Remove the screw circled in red.
Carefully remove the camera.
Remove the nine screws circled in red.
Remove the headphone jack and attached flex cable.
Remove the speaker assembly which also contains the dock connector, antennae and home button as well.
Remove the 2 screws circled in red.
Place the ******** assembly to the side.
Remove the 2 screws circled in red. You will find 3 screws on the opposite side which must be removed as well.
Lift the LCD free from the front panel glass.
Pictured is every component inside the iPhone 3G.
You did it!
on Jul 20, 2008 | Apple iPhone 3G
Some cables not long enough, can they be extended or can longer cables be ordered
yes you can extend the cables, also you can buy cable extenders for video and power cables.
Jan 27, 2014 | SWANN Security Products PRO-530...
How to install my plextor rewritable drive
Okay.....this one is strange. Check on the back of the DVD Drive. You should see if it has connections on it. if it has two "L" Looking slots, then you will need SATA connectors. If you see a bunch of gold pins lined up in a row of TWO, then you need IDE/ATAPI Cables. You will have to take the side panel off of your desktop and look for the connections on the motherboard. Once you have identified the connections on the motherboard, you will have to install the DVD writer into a blank "Slot" on the upper case of the Desktop. you can go to www.youtube.com for demo videos on how to do this Shannon. And PLEASE do it yourself; you will teach yourself something and it will be fun!!!
Jan 25, 2014 | Plextor PX-891SA internal writer DVDRW 24x...
I plugged the wrong USB cord into my camera. What is most likely to be broken, the USB cord plugin or the camera plugin?
USB cables are standardized. If the ends fit the openings, the cable will work. There is one exception, certain USB cables are used to recharge batteries. These are missing the 2 communication wires. Unless something is physically broken, or the cable was jammed into the opening with great force, just try another cable.
Mar 26, 2013 | Kodak EASYSHARE M1063 Digital Camera
Help
Hi, Flat panel television instruction manuals are not very easy reading material, there are many connections on the back-you need to plug in some sort of input-always coming from the " out to T.V." of another device. Cable coax's are most common-the cables aren't very flexible that's one way to tell them apart from an RCA cable-usually with red, white, yellow,green and blue colored ends. The red, white and yellows are what we'll focus on for now-the yellow's are for a picture-connect them from an " out to TV" to " video input" on the back of tv, then for sound likewise- red and white colored from an"audio out " to "audio in " if coming from a VCR-you may use the rather un-flexible " screw on" coax connector-same if coming from a satellite/cable box-some satellites require tuning tv channel to # 60 for a picture-other wise it's channel 3 or 4. although you will get a better picture using yellow, red & white rca cords. I hope this has been of some help, prodzilla
Mar 31, 2011 | Televison & Video
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Find manual for plexor px716uf. Have not been able to download from any ''on line'' site.
Please click on the link below to get your free copy of the manual:
http://www.retrevo.com/support/Plextor-PX-716UF-DVD-Drives-manual/id/20028dj787/t/2/
Click on "Get Manual" and on the next page under "Download instruction" go to "Type the no. shown below".
You woudl be able to download the copy of the manual,
Please let me know if the above solution helped.
Please rate the level of assistance provided
Mar 02, 2010 | Plextor (PX716UF) DVD±RW Dual Layer...
How to connect a Nintendo Wii Audio Video ED Component Cable ?
Generally the Red, Blue, and Green are video with the remaining red and white are audio left and right respectively.
Dec 28, 2008 | Nintendo Wii Console
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Plextor PX-708A DVD±RW Burner Logo
311 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
DROPNDEAL
DROPNDEAL
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
