Question about Compaq A1500 All-In-One InkJet Printer
Compaq a1500 printing probs
When i tried to print anything it tells me its being used by a different application and to wait till its done but i dont know of any other applications being printed, i did upgrade from win me to xp and same problem, worked fine at one time but not now.sometimes if i unplug the power cord and then try it works and it also says i have a paper jam but i dont...are recieved faxes stored in memory so i can later print them and if so how? pleeeez help
  • tomcatusa Jul 10, 2008
    Thanks for trying but ive tried that many times...it was my first guess also:}
  • 31 Answers
Ok you might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
Posted on Jul 09, 2008
  • Steven Velazquez Jul 10, 2008
    awww im really sorry then..hhmmm..maybe you should contact the printer brand, because the printer seems to be the computer piece with the most problems.
Compaq A1500 all-in-one/message:clear system err then press clear
1. Lift the control panel by grabbing the panel along
the top edge.
2. Pull the control panel forward.
3. Lift the ink cartridge access door. For better
access, stow the document input tray away. The
cartridge carriage will move to the center.
4. Remove the new ink cartridge from its
packaging. Hold the ink cartridge by the black
areas or colored top only.
5. Remove the tape covering the print head by
carefully pulling on the yellow tab. Be sure to
remove all of the tape.
May 25, 2009 | Compaq A1500 All-In-One InkJet Printer
Compaq A1500 all in one
Did you trying going to printers and setting default printer? Also click online for the Compaq A1500.
Aug 24, 2008 | Compaq A3000 All-In-One InkJet Printer
Printing 1 out of range of pages only
I had this problem with my Compaq laptop and X7350 and I contacted Lexmark and they gave me a patch to run called "UACpatch.exe" or something like that and it fixed my problem.
Aug 12, 2008 | Lexmark X7350 All-In-One InkJet Printer
Won't print
Ok I just solved a persons problem that is very similar to yours. OK So I'll just paste what I told the other person. You might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
May 26, 2008 | Compaq A1500 All-In-One InkJet Printer
Printer wont print anything
Did you mean just the cord was repaired or did you get a new pc??? Many times, once a computer is unhooked and transported to be repaired, sensitive settings and drivers can be upset by the move. Sounds bizarre but i know it happens because it even happens to me. The other thing is did anything get done to the internals of your pc, or the software changed. This is really important too. ie, did the repairer have to change any settings in the pc, in windows or any where. Please post exact changes if any. If no settings were touched and it was just the cord, i suggest completely uninstalling the printer from the pc. If you do not know how to do this, post back. Once all traces are removed, reinstall it. Make sure printer is completely uninstalled and new installation is smoothe and no hiccups. Now connect back up correctly and turn on. Your pc should recognise new hardware and configure it for you and away you go.
Apr 25, 2008 | Compaq A1500 All-In-One InkJet Printer
Check cartridges error mgs.
The only thing you can do here is by a second set of cartridges and swap them back and forth when they run out. Somehow the printer recognizes that the same cartridge was re-installed. But as I said if you have a second set than you can re-fill the second set and they will work. Then when that runs out refill the first set and install those. Go back and forth between the two sets and you will be fine
Dec 29, 2007 | Compaq A1500 All-In-One InkJet Printer
Printing in different regional language
pls try to reset the printer default seeting .that will fix your regional setting
Dec 10, 2007 | Epson LX-300 Matrix Printer
Printer
You may have the printer settings set to pause accidentally or set to work offline. Go to printer icon, right click and scroll down to check all your settings, if any of above apply, untick them. Try again. The error message is telling you it cannot communicate with the pc. Have you updated anything on your pc, sometimes new systems settings, particulary windows updates and service packs can cause drivers to become incompatable. If all else fails, you could try getting updated drivers from the Compaq website.
Aug 17, 2007 | Compaq A1500 All-In-One InkJet Printer
Compaq A1500 All-In-One InkJet Printer Logo
99 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
