Question about Tech Solution TS-8000 Cross-Cut Shredder
Loud grinding noise when the shredder is on.
We turned the shredder on this morning and it started making a loud, grinding noise. At first, when all the paper was cleared out it was quiet, but now it just makes that noise no matter when it's on.
How do I fix this?
  • sislisa4895 Aug 19, 2008
    I was having the same problem: Loud grinding noise when shredder is on. Now the machine will run in reverse but not forward. It's trying to move forward . . . may move a fraction of an inch then stop, a few times, then stop. Teeth were cleaned thouroughly inside, but hasn't helped. Perhaps there may be a staple caught inside some where.
Your gears may be stripped - mine were. Time to get a new shredder
Posted on Sep 02, 2008
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
The dryer is making loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Jun 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
May 21, 2010 | Quartet gbc 2230S Shredder
Loud grinding noise and doesn't take paper.
sounds like the shaft has slipped off the bearing end support.
disassemble and make sure end plates/bearings and shafts are in proper position, and try again
Mar 31, 2010 | Office Depot Ativa DQ60M Shredder
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
Apr 10, 2009 | Medium Universal Office 38082 Shredder
REALLY loud grinding noise
If it doesn't work at all, there is a reset button for the unit. After it is reset keep the cutters lubed.
Jul 16, 2017 | Royal CIA 12X Shredder
Tech Solution TS-8000 Cross-Cut Shredder Logo
1,977 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
