Question about Garmin Nuvi 660 GPS Receiver
Won't pick up satellites
Our Garmin quit picking up sattelite reception. Reset won't reset.
  • 16 more comments
  • slsbryjr Jul 10, 2008
    Garmin quit picking up a signal......can't locate satelites.
    I have reset it but still doesn't work.
  • rvalentine Jul 10, 2008
    I have the same problem as well happening on the same date!!!
  • Anonymous Jul 10, 2008
    Won't pick up satellites and constant static sound.
    We've reset and tried several times to turn it off and on.
  • pnaski Jul 11, 2008
    My 660 satelitte connection also stopped working on July 9th too?? anyone have any clue what happened and how to fix it?
  • leapsystem Jul 11, 2008
    wont pick up satalite
  • Anonymous Jul 12, 2008
    Mine started having issues on 9-Jul-2008. Died today. "Acquiring Satellites" -- but never connects. No longer will turn on without being plugged into cig lighter or computer. I tried loading patch, but this did not correct.
  • Virtus Jul 12, 2008
    I have the same issue too, and on the same date!? I updated the software and also performed a "Master Reset" still no luck.
  • patrick99nl Jul 13, 2008
    Same issue here, seems my GPS SW crashed as the version is 0.00 !!
    Anyone knows where I can download GPS SW for the 660?
  • haselmere Jul 13, 2008
    Same problem, stopped picking up satellites on afternoon of 08 July and ever since. Just shows, "Acquiring satellites." Re-booted twice, no improvement.
  • Anonymous Jul 13, 2008
    Same problem
    Started about 3 days ago... It will not pick up satellite.
  • adsingh Jul 14, 2008
    My 680 GPS software shows version 0.0 and in System settings it shows Garmin lock -- Off and when I try to enable it it asks to open antenna but does nothing even on opening it. Any suggestions how to get GPS working
  • matadarobert Jul 16, 2008
    no satilight should i take it back
  • fixxser Jul 19, 2008
    Exactly the same problem. It just dropped signal about 3 or 4 days ago and has never returned.
  • jleboeuf99 Jul 22, 2008
    I have the same problem with my nuvi 660, what the heck is going on, I did a reset, thank goodness I wasn't where I really needed it. I also have a tomtom and it works just fine, wonder if its a garmin issue? Has anyone called garmin?
  • grunt03 Jul 24, 2008
    same problem here. tried the reset etc. doesn't work. no indication it is getting any signal from the satellites
    bill
  • Anonymous Jul 28, 2008
    My son was returning to the U.S. today from a trip to Montreal and after they passed through the border he noticed that the unit can no longer pick up any satellites. I have reset wit the switch in the back of the unit and a "Master reset by holding the lower right hand corner of the touchscreen while powering it up and nothing works still not reception. I asks me if I am indoors when I say No it asks me if I am in Kansas. Help
  • fran554 Jul 28, 2008
    in Kansas. Help
  • Anonymous Mar 28, 2014
    The garmin that I have is not picking up some street locsions like whin I put in a wash DC locsions it do not pick up
It fixed my garmin Nuvi 660:
With the unit off press firmly on the upper left hand corner of the screen with the tip of your finger.
2. Press the power button. When you see the screen light up let go of the power button but continue to press on the upper left hand corner of the screen until you receive the message "Do You Really Want to Start Up In Maintenance Mode?"
3. Say Yes and then select the third Option "Clear All User Data" and then say Yes.
4. The unit will then start up and ask you to set some preferences.
5. Once the unit is on the Main Menu please sit it in a safe place outside with a clear view of the sky for about 10 minutes and let it lock on to the satellites.
Posted on Jul 29, 2008
My Garmin 660 won't pick up satellites. Got any suggestions?
Posted on Jul 09, 2008
Having read a previous solution, I can confirm that buying a cheap (about £6 via Amazon) external GPS antenna with MCX connection worked beautifully. The unit is now fully operational again.
Posted on Jul 22, 2008
How can i get my garmin nuvi 1300 to pick up satellites?
GPS satellite reception is best achieved when the unit is outdoors and has a good clear view of an unobstructed sky. The majority of the GPS satellites orbits are around the equator so if you are in the northern hemisphere, the best reception would be achieved with a clear southern sky.
Sep 26, 2011 | Garmin nuvi 1300 Car GPS Receiver
Been on before ,cannot pick up sattelite, getting worse by the day ,getting quite annoyed as this happens more often than actually works .at moment still not picking up sattelites. have had this before...
I understand your frustration - but don't toss it yet! Try a hardware reset first.
1) Lift the antenna up as usual.
2) Locate and press the small button on the rear of the nuvi (that was covered by the antenna).
3) Hold it in for 3 seconds.
4) Place it into the cradle / charger and it will turn back on and operate normally.
Good luck!!
Sep 06, 2011 | Garmin Nuvi 350 Car GPS Receiver
GPS won't pick up satellite reception.
Let's assume the unit is in good conditions. When you travel for more than 500 Kms the unit need more time to acquire the satellites, so the solution is to keep the unit on in a uncovered area for about 15 minutes.
Regards
Osiris
Aug 11, 2009 | Garmin eTrex Legend GPS Receiver
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
My garmin nuvi has lost satellite service and cannot find any satellite service at all. how can i resolve this?
this could be that you are in a poor reception area, have you tried driving around to see if it picks up a signal elsewhere ?
The internal antanea may be faulty, does it have a socket to add an external ?
Has the unit got a reset switch ?
Mike @ Compurepair.
Jun 13, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 660
Go to a clear sky with a clear reception, or try reseting your GPS.
if you just happen to enter new information while driving this would sometimes freeze your GPS as a protection whilst driving
Jul 14, 2008 | Garmin Nuvi 660 GPS Receiver
GARMIN DOESNT PICK UP SATELLITES
You have a problem with your internal antenna. You can easly reslove this by hooking up an external antenna, and watch it go from 20 to two mins.
Feb 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
2,041 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
