Question about Canon NP 6050 Copier
NP4050 EO2O ERROR
I NOTICED THE TONER IS OVER 50% BUT I CANNOT GET THE KEYS TO DO ANYTHING.HOW DO YOU GET INTO THE SERVICE MODE AND WHAT STEPS SHOULD I TAKE
  • WVF_32000 Jul 09, 2008
    CODE IS E020 FOR THIS NP 4050 CANNON COPIER
  • Canon Expert
  • 1,326 Answers
The error code means that the toner level in the developing unit is low. The ATDC sensor is probly bad or it is caked with toner and it is not reading correctly..... Good luck finding one.
Posted on Jul 10, 2008
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
What's E00025-2c0
Error in Cover Sensor (PS14) in M Toner Container
Description Unable to detect opening of the Toner Container Inner
Cover when removing the Toner Container.
Remedy Identify the cause of the error whether it is due to link
mechanism to open the Toner Container Inner Cover or
problem at the Toner Container Inner Cover Sensor side. ?
1. Perform the user mode (Adjustment/Maintenance>
Replace Specified Toner) to check if the Toner Container
Inner Cover opens normally (damage, slide of shaft area,
etc.). ?
2. Check if the Toner Container Inner Cover Sensor is
soiled and the installation of the sensor. ?
3. Check the service mode (COPIER> I/O> DCON> P024
bit9) to see that the output value of the Toner Container
Inner Cover Sensor is changed normally when opening/
closing the Toner Container Inner Cover. ?
If it is normal, the value becomes 0 by rotating the Set-on
Drive Shaft with the attached tool and opening the Toner
Container Inner Cover. When closing the Toner Container
Inner Cover by hand, it becomes 1. ?
3-1. When the Toner Container Inner Cover is not opened
although the Set-on Drive Shaft rotates, check the drive
system from upstream (Set-on Drive Unit -> Hopper Unit
-> Bottle Base Unit -> Toner Container Inner Cover Unit). ?
If it is damaged, replace the damaged part and then
perform step 5 and later steps. ?
3-2. When the output value is not changed normally
although the Toner Container Inner Cover can be opened/
closed, check the Sensor Harness (to see if the harness
is caught, disconnected or physically removed, *including
the Relay Connector). ?
If there is no problem, replace the sensor. After checking
the output value in step 3, perform step 5 and later steps. ?
4. If the problem is not solved by replacing the foregoing
parts, replace the Drum Driver PCB (UN4) and then
5. Clear the error in service mode (COPIER>
FUNCTION> CLEAR> ERR), and then turn OFF and then
ON the main power. ?
6. Replace the toner (reinstall the removed Toner
Container) at least once in user mode (Adjustment/
Maintenance> Replace Specified Toner), and check that
toner replacement can be performed normally.
Sep 24, 2014 | Canon imageRUNNER ADVANCE C5051
How to reset error c2558 in bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :-
Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer.
Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine.
Step-3. switch Off & re - switch on the machine .
Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION.
Step-5. Press [OK].
Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR.
Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number
Step-8. Turn the machine off the main switch.
(finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside)
If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer.
Installing the toner bottle :-
Step-1. Before using the toner Shake the toner bottle.
Step-2. Open the front door.
Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle.
Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle.
-----GOOD LUCK-----
Aug 13, 2014 | Office Equipment & Supplies
Error code c2558 for konika bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :- Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer. Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine. Step-3. switch Off & re - switch on the machine . Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION. Step-5. Press [OK]. Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR. Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number Step-8. Turn the machine off the main switch. (finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside) If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer. Installing the toner bottle :- Step-1. Before using the toner Shake the toner bottle. Step-2. Open the front door. Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle. Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle. -----GOOD LUCK-----
Jan 15, 2013 | Konica Minolta bizhub C450P Laser Printer
Minolta bizhub 164 error code C2558..how can I solve
Step-5. Press [OK].
THATS IT - YOU ARE DONE - FINISHED
DONE - ERROR REMOVED
-----GOOD LUCK-----
Mar 06, 2012 | Office Equipment & Supplies
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
What is a service code c2558 mean on my copier?
C2558: Abnormally high toner density detected black TCR sensor
Reinstall imaging unit
Reinstall toner cartridge
Change imaging unit/K
Change PRCB
Sep 28, 2010 | Konica Minolta Bizhub c203 Copier
HOW CAN I RESOLVE ERROR c6000 in fs 1118
This might take some doing reseting the fs 1118 but it can be done if the fuser only got hit by a powersurge or overheated due to paperjam by the fuser...
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
press enter
enter 163 and then restart the copier...
sometimes you wont even be able to get to the service mode...
open the front of the copier and then execute the steps... the front meaning the area where you the toner is located...
trying keeping it open and do the steps...
if that fails then open it take out the toner drum cartridge and then put it back in...
then do the steps...
if it still doesn't take try it a couple more times...
if it still doesn't take.. buy a new fuser...
but it should take... it just takes a little experimentation...
Jun 22, 2009 | Kyocera FS-1118 Printer
Canon NP 6050 Copier Logo
60 people viewed this question
old marine
old marine
Corne Viljoen
