Question about Bernina Bernette Deco 600
Top color thread showing on bottom of embroidery on a Bernina Deco 330 embroidery machine
My bobbin thread shows on top sticthing
Posted on Mar 05, 2013
  • 323 Answers
Upper tension is too loose or lower tension is too tight.This might be a good thing. It depends upon how much it is pulling the thread under. A perfect tension on embroidery is about 2/3's lower thread and 1/3 upper thread showing on the bottom.
sewman7
Posted on Jul 10, 2008
My bottom tention of Bernina Deco 340 is to loose. How to I correct is. The top treat shows to much at the bottom
Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
Aug 24, 2017 | Bernina Sewing Machines
Bernina Deco 330 embroidery machine bobbin case tension.
There are tests to perform for testing and adjusting bobbin tension. There really aren't any "specifications" other than adjusting it until the bobbin drop test is where it is normally recommended.
adjust bobbin tension Google Search
P.S.--be sure to ALWAYS raise the presser foot when threading the upper thread to insure the thread seats completely in the tension disk.
Aug 22, 2016 | Bernina Sewing Machines
My pr 600 freezes
You might have Thread particles build up. Puchase canned Air for electronis and use it on a regular basic to clean your bobbin case area. Also when you change threads color always clip your thread near the spool and pull your thread out from the bottom near your needle. When you pull your thread through the top little pieces of the thread break of and fall into the chamber of your embroidery machine .
Mar 05, 2014 | Bernina Bernette Deco 600
I have the Deco 600 and it's a workhorse! I love the machine. I just had it serviced and now when I embroidery and use white bobbin thread it shows on top. I have tried adjusting the tension like the...
I have a 600 also...have you changed brand of white thread? Sometimes it can be the design you are embroidering that will bring bobbin thread to the top. I use the prewound bobbins--very thin thread & tightly wound.
Jun 15, 2011 | Bernina Bernette Deco 600
I have a Bernina 340 Deco embroidery computer. I am having trouble (lots) with the thread looping on top of fabric.
Make sure the bobbin case and shuttle are free from any thread tangles.
Thread with the presser foot up.
If problem persists, the machine will need to go into the shop where an authorized Bernina tech can check the timing and do a general service of the machine.
Take a sample of the mis-stitching.
Mar 20, 2010 | Sewing Machines
DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART EMBROIDERY DESIGNS SUCH AS I USE FOR MY ARTISTA 730E? ALSO, DOES BROTHER MAKE THE BERNINA BERNETTE DECO 600?
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
Jan 05, 2010 | Bernina Bernette Deco 600
Just got my used Bernina deco 650 from the shop. Tension off
The tensions are not calibrated properly. To get by, or if you do not want to take it back to the shop, just lower the upper tension a little at a time until it looks ok.
I have 25 years experience working on sewing machines
Jun 29, 2009 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Oiling Bernina Deco 330
Use only good quality clear sewing machine oil from your Bernina dealer--ask them which is the correct oil for your machine. The likely place to oil is in the hook area (see page 44 of the manual). Be sure to apply a drop or two every 8 hours of sewing time. If you know your machine, you may notice a change in sound when it needs lube. Oiling anywhere else could damage your machine.
Do NOT place lube in any holes (as previously suggested) in the bed or top of the machine. These are not oil ports. They are holes for fastening accessories to your machine, ie circular embroidery unit, binding units, seam guides, etc.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi8ubHe6o7XAhXpi1QKHb3zAngQFggxMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FBERNINA-Nah-und-Stickmaschinen%2FBERNINA-3er-Serie%2FManuals%2F0333017104_2014-02_Manual_B330_B350_B380_EN-us&usg=AOvVaw0F7ScSQEEitpxEnDD0v8Y1
Oct 26, 2017 | Sewing Machines
Sewing Machines Logo
404 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
