Question about Miele Washing Machines
I have a Miele Special Electronic W757 front loader that comes with my rental property. It has no instructions and is not completly emptying water when it spins . I know that the filter needs to be cleaned. I can see the cap to unscrew but there is no little hose to drain off the water before i open it.
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
  • 5 Answers
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Posted on Mar 05, 2009
jan mczeal
  • 632 Answers
SOURCE: oe message on lg front loader washer model
It is a long drain error and occurs when the washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Drain Pump Connector The connector may be disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Posted on Nov 24, 2009
  • 572 Answers
SOURCE: front loader frigidaire wont spin or drain final
in the bottom panel theres a coin trap
Posted on Feb 06, 2010
My miele front loader beeping and display saying activated close stopcock.
Defective door lock switch Manual release in side back of door lock
may have pull wire near drain clean out.
Jul 05, 2016 | Miele Washing Machines
Suds in rinse cycle
There are a couple of reasons why this may happen. You may have accidentally purchased top loader powder instead of front loader powder. Have a look on the side of the box as this is an easy mistake to make which causes excessive suds.
Secondly you may be over filling the dispenser tray. You don't need to put anymore than about 1/3 of a scoop of detergent in despite what the manufacturer suggests on the box. They just want you to use more so you purchase more.
Try flushing out the machine by doing a few empty cycles with no clothes or detergent on 95c with a cup of white vinegar in the detergent dispenser when it goes to fill with water. I recommend you doing this every month anyway to clean out the drum and kill off any bacteria so the door seal doesn't create mould.
Hope this helps.
May 08, 2014 | Miele Dishwashers
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
Hi There, We are in a rental property and have a bosch 21e hot water system. We haven't been getting hot water and the gas bottles have been checked and are full. Do we have to light the pilot and are...
You may have a dirty pilot orifice. Try this. Turn off the pilot by turning the control knob to off. Remove the front panel to get access to the pilot orifice. Use a can of compressed air with attached straw (the same stuff you use to clean computer keyboards) and blow out the pilot orifice, which is inside the pilot assembly where the pilot flame burns. Blow it out from the top and from the sides through the air holes. Then relight the pilot and see if that improves the flame size and color (blue) to heat the thermocouple.
Here is a link to the manual and instructions. www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125B_manual.pdf
Mar 23, 2011 | Heating & Cooling
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
I have water in my front loader when empty
Water is siphoning back in! Make sure there is a siphon break or vent at the end of your drain hose to stop this problem for sure.
May 15, 2010 | Washing Machines
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
