Question about Marantz Audio Players & Recorders
In a guest house and the Marantz SR4500 keeps coming up with "PROTECT" afetr power up. Have tried to reset but still there. Go about 5 seconds or so then Protect flashes and the unit shuts down. No audio as well.
    President:
  • 624 Answers
Have you tried the reset procedure I am outlining below at the end of this post?
If you have not done it exactly this way, try it. The "protect" that is displayed is the protection circuit being activated. Most times it is activated is to prevent further damage to the unit. Sometimes it can be activated from the unit being over-driven (played at very loud volume for prolonged periods or having the improper speakers or a bad speaker).
If this reset procedure does not work, you need to take it in for service preferably at a Marantz authorized service center because the problem you are having is not something that can be fixed by any sequence of keys being pressed. It normally happens when the unit has a blown channel. That is not the only reason, but it is the most common reason.
If you have the proper tools, a schematic, and knowledge of how to check electronic components to know when they are faulty, you can then fix it yourself. If you do not have these tools and the proper skills, you can cause much more damage to the unit than you started with, even to the point of starting a fire or making the unit un-fixable. This type of unit is not an easy one to repair, even for a well trained electronic technician. I work at an authorized Marantz service center and have repaired many of these and other receivers over the past 17 plus years.
Be aware, by using this procedure and then turing the unit on can sometimes cause more damage to the unit if it has a shorted channel or other problem that makes it draw a lot of current. This method is meant for qualified service technicians to perform after they have checked the output stages for any problems and the unit is still in the protect mode. You have been warned, so don't say I didn't tell you it should be taken to a service center first. If you see or smell any smoke or buring smell, unplug the unit immediately. You may want to have one hand on the plug when you do this, just in case.
Here is the proper reset procedure:
SR4500 Turn the unit on (standby without pressing the power button), press and hold the 7.1CH INPUT and ATT buttons simultaneously for3 seconds or more.
If you have found this free information helpful, a "FixYa!" rating would be appreciated, and if you need any more help I am happy to offer it, just ask!
Dave
p.s. I have told you all the warnings and suggested a service center because this is a very good receiver and I would hate to see it damaged more than it may possibly have already. It is possible that this reset procedure will return the unit to normal operation, but more often than not, the "protect" circuit activating means that you have a serious problem that can not be fixed by anybody without the proper training.
Posted on Jul 09, 2008
  • Dave DeGain
    Dave DeGain Jul 16, 2008
    Thanks for trying?
    I give you the absolute best advice you can get for this unit and you give me a bad rating for telling you the truth about what is happening. I actually fix these things for a living, you would have a very difficult time finding anybody who knows as much about these receivers as I know.
    Let me know when somebody else gives you the key combination or invents the magic wand to wave over your receiver that magically repairs the shorted output transistors and fried resistors in the amp circuit that you most likely have.
    Sometimes I wonder why I give out good technical knowledge for free and then get a bad rating for trying to help somebody.
    Thanks for Trying, ya, right, thanks
Wow, talk about losing it!
Actually, he gave you a bad rating because your information is incorrect!
There is no 7.1 button, only a 6.1 one but do not touch this as the reset will then not work!
To do a reset on a Marantz SR5400 one needs to have the power ON and press the SELECT and ATT buttons simultanously for at least 3 seconds.
Posted on Jun 27, 2012
How to reset marantz sr4001 from protect mode?
Protect mode comes into play when there is a problem with the speakers or amplifier First check all the speakers for opens or shorts If they are fine you don't reset it you repair the receiver.
Aug 07, 2014 | Marantz Audio Players & Recorders
Protect message
If you are using AV cables from your TV for movies and a different hookup for the X-Box would explain that the relay for the sound inside your unit may have blown from being overloaded or faulty. Should be an easy fix at a trusted electronic service place.I am not sure if your system has a manual reset button underneath or on back, but you could look for a tiny hole with reset on it or a red button. It may save you a trip to the doc.
Nov 11, 2007 | Marantz SR4500 Receiver
Tip
How to Reset Windows Password With an Standard User Account?
When you <a href="http://www.windowsloginrecovery.com/forgot-windows-password.html">forgot Windows password</a>, did you feel confused that why you cannot reset the forgotten Windows password via standard user or guest account? The answer is very simple as the standard user and guest accounts do not have rights to reset the password of another accounts. Within the three types of Windows user accounts, only the administrator account allows you to change another accounts' password. So if you want to <a href="http://www.windowsloginrecovery.com/reset-windows-password.html">reset Windows password</a> of another accounts, you need to change your account type to administrator firstly. Moreover, if you need to give a user more access to perform tasks like installing software or other system changes, you also need to change your account type.<br /><br /><span style="font-weight: bold;">Steps to Change Windows User Account Type</span><br /><br />1. Log on your Windows machine with an administrator account.<br /><br />2. Click "Start" - "Control Panel" - "User Accounts and Family Safety" - "User Accounts".<br /><br />3. Click "Manage another account".<br /><br />4. Click on the user account that you would like to change its type.<br /><br />5. On the following window, click "Change the account type" from on the left pane.<br /><br />6. Select Administrator and click "Change Account" Type to finish your operation.<br /><br />Since the standard user account turn to an administrator one, you can reset Windows password of another accounts or do other operations without limitation through control panel.<br /><br />You can change standard user to administrator only when you can log on your computer with an available administrator account. If you forgot Windows password of all administrator accounts, you'll need to reset Windows administrator password even you can access your computer with a standard user or guest account.<br /><br />Software Windows Login Recovery allows you to create a password reset disk with blank CD/DVD or USB flash drive. With the disk you can reset Windows password to be empty in few minutes. With it, you'll never be worried when you forgot Windows password. All you need to do is just three steps.<br /><br />1. Download and install Windows Login Recovery.<br /><br />2. Burn a password reset disk with a blank CD/DVD or USB flash drive.<br /><br />3. Reset Windows password to be empty.<br /><br />Now you can log on to your computer without passwords. By the way, you can reset any account's password with this software. <br /><br /><span style="font-weight: bold;">Something about Windows User Accounts</span><br /><br /><span style="font-weight: bold;">Administrator:</span> A administrator account is intended for someone who can make system wide changes to the computer, install software, and access all non-private files on the computer. Only with administrator rights you can full access to other user accounts on the computer, change other their names, passwords, and types.<br /><br /><span style="font-weight: bold;">Standard user:</span> The standard user account can help protect your computer by preventing users from making changes that affect everyone who uses the computer. When you log on to Windows with a standard user account, you can do anything that you can do with an administrator account. But if you want to install software or hardware, reset Windows password of another accounts, etc. the computer might ask you to provide a password of an administrator account.<br /><br /><span style="font-weight: bold;">Guest:</span> A Guest account allows people to use your computer without having rights to access to any of your personal files. This can be useful if you want to quickly allow someone to use your computer. A person that log on computer with guest account cannot install software or hardware, change system settings, or create a password.
on Dec 24, 2010 | Computers & Internet
Marantz sr4002 - Power light blinks but power will not come on. Tried the reset trick and no response. ???
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 22, 2011 | Marantz SR4002
We have a Marantz sr4500, everytime we put it on it makes a Zzzzzz sound and then it turns off with a loud "buk" sound and shows protect on the amp's screen, after few seconds the amp turns...
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.In this case I think that some capacitors are faulty as when the set is put on it charges on to make the amplifier work. Possible fault in the protect circuit or preamp.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
May 11, 2011 | Marantz SR4500 Receiver
How do you program it without the remote
You can do it by using the arrow keys at the front panel.Study the user manual before that.
Dec 06, 2010 | Marantz SR4500 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
Obstructed ventilation holes?marantz sr4500
if your amp doesnt have air vent fins on the sides you shouldnt have any problems with overheating
Dec 29, 2007 | Marantz SR4500 Receiver
Marantz SR5000 Protect mode
The Marantz SR5000 and others of it's make, design type, and year group are prone to this problem. Many such units can be reset by pressing a sequence of three buttons with sporadic results... the SR5000; however, does not provide any such option. If the "Auto protect" mode comes "on" then you know it's not a simple power supply "fuse" problem that can be fixed for a dollar by opening the case and replacing the glass fuse with one of the same rating value that is stenciled on to the power supply circuit board. (Easier than trying to read the old fuse.) If you can get the schematics and know a bit about replacing electronics parts using a low-power soldering iron, then you might want to take a shot at fixing it; otherwise, it's time for recycling. (Tip: Look for discolouration on a part on a circuit board first, this indicates overheating and a possible short. Then trace the schematic circuit for the "Auto Protect" circuit to diagnose which integrated circuits is at fault.) Typically, it costs more to fix it in a commercial shop than it's worth as someone has to pay the cost of benchtime diagnostics... the repair part is fast once the faulty parts are discovered. There are free sources on-line of the service guide for this receiver; however, downloading the plethora of rar files to assemble a complete manual is a challenge.
May 13, 2007 | Marantz SR-5000
489 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
