Question about JVC Televison & Video
I need to replace the front screen panel. How can I? Thanks
  • trifive Jul 10, 2008
    Sorry, it's the jvc hd56gc87
    Thanks again
  • JVC Master
  • 8,617 Answers
Need the model number to help you, as they are all somewhat different depending on model. Please reply to this same post with the model number of your set.
Posted on Jul 10, 2008
How do i replace iPhone 5s screen
iPhone 5s Screen Repair done in 11 minutes. Best video ...
? 11:08
https://www.youtube.com/watch?v=UkltRLdfYBs
Oct 24, 2013 - Uploaded by JerryRigEverything
MAKE SURE YOU PUT THE HOME BUTTON ON CORRECTLY LIKE HE MENTIONS. Everything else you need ...
iPhone 5 Front Panel Replacement - iFixit
https://www.ifixit.com/Guide/iPhone+5...Replacement/10906
iFixitiFixit - iPhone 5 Front Panel Replacement: Replace the Front Panel on your iPhone ...iPhone 5 LCD Screen and Digitizer, Fix Kit / Black This kit contains the part ...
iPhone Screen Damage Repair - Apple Support
Jan 18, 2016 | Apple iPhone Cell Phones
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
I need to replace the lamp on my TV. I have
The bulb should be in the front on this unit. Under the screen there is a panel which needs to be removed to access the lamp panel. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to do this and where to get the parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replace door cables
Download this manual:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
You will need to remove the lint screen, the top (page 19) the toe panel (page 20) and then open the front panel (page 24) and then change out your door cables.
Thanks for using FixYa.
Kelly
Mar 04, 2010 | Dryers
How to fit a belt for a indesit dryer ISL70c
Hi
Thanks for using FixYa. Please follow the step-by-step procedure---
1. Remove the front panel.
2. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
3. Remove the drum and belt from the cabinet.
1-- Prepare for replacing the dryer belt by lifting the lint-screen cover on the top of the dryer. Then remove the lint screen. Skip this step if your lint screen is inside the door. Remove the 2 Phillips screws inside the door instead.
2-- After removing the lint screen, lift the cover and remove the screws that hold the lint-screen housing to the dryer top.
3-- Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
4-- To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
5-- Place a few wood blocks under the drum. These support the drum when the front panel is moved away from the sides.
6-- Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
7-- Remove the screws that secure the front panel to the dryer sides at the top. These are accessed from the inside of the cabinet.
8-- Lean the front panel away from the sides and slip the new dryer belt over the drum. Then re-secure the front panel.
9-- Check that the lip on the back of the dryer drum fits properly against the seal on the rear bulkhead of the dryer.
10-- Locate the original position of the old belt, and slip the new belt in place. Keep the grooved side of the belt down.
11-- Push the idler pulley toward the motor and loop the doubled-up belt around the idler pulley. Slip belt around motor pulley.
12-- Rotate the drum counterclockwise a few turns to check belt tracking. Then replace remaining components and test run.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 20, 2010 | Washing Machines
Cleaning plasma screen
I wouldn't use the screen cleaner as I have seen it discolor the Front panel of the plasma before. Then the panel needs to be replaced.
Just put a small amount of water on a VERY soft clothe and clean it like you would a window. Do not spray onto screen as that can cause problems.
Mar 28, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Main control panel
Hello Dennis,
Welcome
You said, You have no leds on the front of the panel. When i switch on the machine all i get in the screen is 188 a snow flake top right of this and an 's' shape top left. Cant reset it holding down the right buttons. Any ideas anyone, is it time to replace it. thanks Dennis
I need the model number and year!
Waiting your response!
Huuum
Sep 03, 2008 | Siemens 24 in. SE25A266 ExtraKlasse...
Blinking auto adjust in progress
The problem is with front panel switches which needs to be replaced.
Samir
Aug 27, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Panasonic th-50px60u
If the glass that you can feel on the front of the tv is cracked, then just replace the glass (called filter). The cost is about 150.00. If the pannel is cracked buy a new tv. It costs to much.
Nov 26, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Front panel removal instructions for
You have to remove the back bottom skirt from television in order to get to the screws for the front bottom panel. When the front bottom panel is removed there will be more screws visible, for front screen. After an afternoon of trying to get it apart, just to clean the mirror on ours, we finally got it.
Mar 31, 2007 | Philips 43P8341 43" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
