Question about GE Refrigerators
We bought a GE Freezer last week and had it installed 7/8/08. Today (7/09/08) the sides and top are extremely hot. Is this because its a brand new freezer? It's located in our garage.
Talked to the seller at Home Depot who said to wait 48 hrs. Problem should be solved. Also in the handbook furnished by GE they mentioned the reason. Problem solved. Thanks anyway. George
Posted on Jul 10, 2008
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
Mar 04, 2014 | Bush Freezers
My Fridge where the doors close is hot to the touch. This is a new problem that prior to today did not occur. I bought a new fridge and put the old one in the garage. It is plugged into a dedicated...
The hot temperature that occurs in the fridge body is normal and you have nothing to worry. It is the result of the heat pumps during a normal operation. Once the fridges reaches the normal temperature it will automatically shuts off and the hotness of the body will disappear.
Dec 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Our GE Profile Model PS123NG/PS123NS came brand
probably a loose thermister. The thermister being not attached to the evap coils tight might not be relaying back the proper resistances info for the control board to make a propper defrost determination.
May 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Brand new GE wont get cold
Sounds like the installers had to remove the doors when the unit was delivered. If they did they might not of hooked the wire harness up at the top of the door hinge or damaged the room thermisters at the top of the door hinge system. Also there is 2 magnetic switches under the top of the doors, you might check the wires on them as well.
Jun 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I had the same problem and when we looked at the back the fan was running very slowly. We replaced the fan and that wasn't it. Then we replaced the board, bought it online for 80 bucks and sure enough that was it. Whirlpool was willing to pay for half of the part if I had once of there technicians come out. I think they know the boards are going on these. Mine is a year and half old. I have read several other sites with people having problems with the board. If the side is very hot, like ours was than this may be it. We just ran a portable fan to the condenser until we got the board in..hope this helps
Oct 13, 2007 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
