Question about ViewSonic VP201b 20.1" LCD Monitor
How to degauss viewsonic vp201b lcd - ViewSonic VP201b 20.1" LCD Monitor
  • 11,361 Answers
You do not degauss LCD monitor, it does not use electron beams (affected by magnetic field, if the showdow mask is magnetized, it can mees up color display) for making pictures like LCD.
You only degauss CRT type monitor.
http://en.wikipedia.org/wiki/Degaussing
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
Viewsonic vp201b pink tint on screen
That sounds like possibly a bad cable or a bad video card. Do you have another cable you can try?
Dec 01, 2012 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic VP201b with Black screen. I think the problem is the back light power supply. If I shine a light on it at an angle I can see the image on the screen. what is the part number to get a replac
The power supply board is model L20C-2 In most cases you can repair the board cheaper than you can purchase a new one. The problem is the filter capacitors go out and this keeps the back light bulbs from powering up right. If you feel like doing the repair on the board here is a link that shows the board with the bad parts circled and a parts list on the capacitors that needs to be replaced.
http://www.ccl-la.com/catalog/product_info.php?products_id=88
Nov 12, 2012 | ViewSonic VP201b 20.1" LCD Monitor
Hi, I have a ViewSonic VP201b monitor that has a problem.... It seems that it wont turn on (BLACK SCREEN *NOTHING*). The yellow light goes on when idle, but when it's not idle the green light isn't...
Get a working monitor and turn on the computer. Then swap the monitor with VP201b.
Get a flash light closer to the screen to see whether you can see the desktop screen image. Yes? Then it is your backlight inverter.
Find a Youtube video to show you how to open the cover. Then look for any sign of broken capacitor(s). Replace them and then test your monitor. If all capacitors are okay, it is one of your FUSES. There are 2 tiny surface mount fuses ("FN" type). You can short the two ends to test it before removing them. Often only one of them is broken. Replace it and the monitor shall be okay now.
May 12, 2017 | ViewSonic VP201b 20.1" LCD Monitor
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Jul 26, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Vp201b wont turn on
Checkto see if you do have 12vdc output from the power supply module as shown in my pictures: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VP201B/
Look for bad caps (leaking/bulging tops).
May 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
Display flickers than scrambles.
Most likely loose connection at PC. Check that monitor connector pins are not bent. Ensure that he monitor plug screws are screwed into the connector to prevent plug movement, at the PC and in the case of some monitors, also at the back of the monitor. If this does not correct the problem, there is probably a fracture in one of the solder joints on the VGA board at the connector.
Mar 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
My viewsonic VA800 just started getting all pixillated - does it need to be degaussed?
mitchpowell, CRT monitors need to be "degaussed". No need for that with CCFL back-lit LCD displays. 12fixlouie
Feb 11, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Sep 11, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Computers & Internet Logo
668 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
