Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have side by side KSRA25ILSS and last week I have noticed-freeser is working OK,but refrigerator-too warm .I reseted sys. couple times,but coudnt fix problem. What is my next step,please?
  • 1,531 Answers
You will need to check the damper control and make sure the door is opening properly to allow the cold air in the fridge this damper is normally located in the back f the fridge top left side.
then you will need to check the freezer compartment and make sure there is not alot of ice or frost build up.You will also need to make sure the evaporator fan is running in the freezer comprtment.
If there is frost or ice build up you can use a blow dryer to defrost it then remove the back panel and defrost the evap coil.you will need to check the defrost heater and temp sensor be sure there are all working good.
Posted on Jan 04, 2011
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
Hoover HCA 33 FSK
gp to repair clinic.com it sounds like the temp sensor or the or the defrost timer either way it probably isit defosting. The fan will run every time the it call for cold
May 29, 2012 | Hoover HCA390FFK Bottom Freezer...
Refridgerator Compressor running does not cool! Freeser fan not blowing warm air!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Westinghouse Refrigerators
Freezer ok, but refigerator is warm
first check to see if the controls have been changed,
one of the dials control overall cooling (freeser) and the other controls a damper that allows cold air from the freeser to travel to the refrigerator.
the other solution could be that there is something in the freeser, food or ice blocking the vent.
one other possibility is that the damper is stuck or frozen still.
if your freezer is ok, it is not a serious problem
May 26, 2009 | Refrigerators
Samsung RS2545SH Refrigerator
Diagnostic mode will say what any electronic issues are. Check to see if there is, if any, frost build up on the rear panel or ports. If the unit had made any noise in the refrigerator. This unit may have a switching valve for the twin cool, so it could be an issue there.
Dec 02, 2017 | Refrigerators
Whirlpool Refrig Side by side
the problem is almost certainly in the controller or its power supply. Try pulling the plug for a minute or two - for some reason the display portion of the controller may have been sent out to lunch by a power surge or alpha particle. It woudn't be the first time. Check for bad connections between the display panel and the power supply and solder joints on the controller board. With everything else operational, a bad microcontroller chip is not that likely but is still a possibility. Good luck
May 18, 2006 | Whirlpool ED2FHSS Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
89 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
