Question about GE EasyCam Webcam
My phones camera says evety time memory full what do i have to do?
My Kodak Easyshare V1253 says memory full for media card when using with flash
Hi hanif304,
Please check if you have the default memory selected as your memory card memory and not your phone memory.
So if your phone memory is selected as default for storage and it's full then you won't be able to store more images before you have free space.
If you have your memory card full and then selected as default memory then the same thing would happen.
A good idea would be to copy the contents of the memory card and/or the phone memory and then format them, this should solve your problem all together.
Hope this helps ...:)
Aug 09, 2011 | Kodak EASYSHARE V1253 Digital Camera
Camera on standby phone memory full whats a sollution
The phone camera can only function when there is available storage for the image(s). So once it if full, the initial storage location is full, then you do have to create space for new images to be stored before the camera can function properly again.
If your phone doesnt have a memory slot, the means that you are limited to the memory size you use, which is your phone memory.
The solution here is to delete some data on your phone, or transfer it to another device. Then restart your camera.
If your phone has a memory slot, but your dont have a micro SD card in it, get one, then start your camera, go to settings, and change the storage to memory card.
If you already have a memory card, and it is not full yet, it means your camera is storing the images on the phone. Go to settings when you turn on the camera, and change the storage location to memory card.
But if you have a memory card, and it is full, you would have to delete some items to create space.
I hope one or more of the instances was helpful to you?
Have a nice day.
Jul 05, 2011 | Cell Phones
Camera not working
Please check your memory card storage also check your phone memory. This may happen because your memory is full
Apr 03, 2010 | Samsung SYNC SGH-A707 Cellular Phone
When i take a photo it comes up some times "unable to save file" and then i lose the photo??help.i have memory card and only a couple of photos so memory not full up i think??
Usually the camera saves the file in Phone memory rather than Memory Card.
So change the default storage to memory card.
It will be under the main settings menu.
Or the camera settings.
You can also make enough space in Phone Memory, so that a picture can accommodate itself, but its not a permanent solution.
If Helpful, kindly Rate.
Jul 17, 2009 | Nokia 5200 Cellular Phone
I get code error E:91:01
1.turn the unit on
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
Feb 28, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Camera Is Not Working
Is the memory card full? try removing some files on and try opening the camera again, normally if the space in full it takes time to initialize.
Nov 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 6600 bluetooth not switched on
adarshmarsha your problem is hardware change bluetooth ic full flash the phone your problem will be solved regards Paljor Lama
Jul 24, 2008 | Nokia 6600
Camera will not stay on
please check if the battery supplied is an NPBG1 battery.
or try this...
1.turn the unit on
3. select setup
if this does not work.... call sony cust service 1800-222-7669
Jan 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Memory Full Error
The problem is with your phone not the memory card. To better solve this problem I will need the model and make of your phone.
Thanks
Jan 08, 2008 | Nokia 1600 Cellular Phone
GE EasyCam Webcam Logo
14 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
