Question about Brother HL 2140 Laser Printer
How do I remove ink cartridge - Brother HL 2140 Laser Printer
    Sergeant:
  • 223 Answers
Just check this video may be it will help you more
Good luck
Posted on Jan 04, 2011
  • B_support_uk Jan 05, 2011
    If you follow the steps in the video above you can cause the toner to leak all in the machine, which then will need a engineer to repair it which will cost money. You are best to replace the toner like the machine was indicating.
Do I have to replace the color ink cartrigdes in my epson xp-610 printer
Q:
How do I change the ink cartridges?
A:
Do the following:
Removing and Installing Ink Cartridges
Make sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
  1. Make sure that the CD/DVD tray is not inserted for printing.
  2. Turn on your product.
    • If an ink cartridge is expended, you see a message on the LCD screen. Note which cartridges need to be replaced and press OK . Then select Yes, replace now and press OK .
    • If you are replacing a cartridge before you see a message on the LCD screen, press the left or right arrow buttons, select Setup > OK > Maintenance > OK > Ink Cartridge Replacement > OK . Then press the start_black_icon.jpg start button.
  3. Lift up the scanner unit.
    Caution:
    Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
  4. Push in the blue tab to unlock the ink cartridge you are replacing. Then lift the bottom of the ink cartridge to remove it.
    Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
  5. Recap the used ink cartridge using the cap that came with it.
    Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
  6. If you are replacing the Black (BK) ink cartridge, it is recommended that you shake the new cartridge gently four or five times before unwrapping it. You do not need to shake the Photo Black (PBK) cartridge or any of the other color ink cartridges.
    Caution:
    Do not shake the cartridges after opening the packages, or ink may leak.
  7. Remove the cartridge from the package.
    Caution:
    Do not touch the areas shown above. Doing so may prevent normal operation and printing.
  8. Remove the cap from the cartridge and store it in the bag that came with your product for later use.
    Note: Save the cap so you can recap ink cartridges before storing or disposing of them.
    Caution:
    Do not remove any other labels or seals, or ink will leak.
  9. Insert the ink cartridge head first into the ink cartridge holder. Then press the bottom of the ink cartridge down until it clicks into place.
  10. Once you replace all the cartridges that need replacing, close the scanner unit.
    The product starts priming the ink. This takes a few minutes. When you see a completion message on the LCD screen, ink replacement is complete. Note: If you see an error screen telling you an ink cartridge is installed incorrectly, lift up the scanner unit and press the ink cartridge down until it clicks into place. When you\'re finished, close the scanner unit.
If you remove a low or expended ink cartridge, you cannot re-install and use the cartridge.
Caution:
If you remove an ink cartridge for later use, recap the ink cartridge using the cap that came with it to prevent the ink from drying out and to protect the surrounding area from getting smeared by ink. Store the ink cartridge in the same environment as the product. Do not leave the product with the ink cartridges removed for an extended period of time. Otherwise, ink remaining in the print head nozzles may dry out and you may not be able to print.
http://youtu.be/xJsDu52txEA
Nov 17, 2014 | Epson Expression Premium XP-610...
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
HOW DO I REPLACE MY INK CARTRIDGE IN MY CANON 2600 PRINTER?
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Good luck
Feb 15, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Ink
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Install ink
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support <1> is fixed into position, release your hands.
    *MP470 shown
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
I hope it helps!!!
Dec 08, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
Nov 12, 2007 | Brother HL-2040 Laser Printer
Brother HL 2140 Laser Printer Logo
132 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
