Question about Oregon Scientific DP200 Clock Radio
My clock is working fine, but the the projector part is broken. The figures is broken, it is not appearing the right numbers. where can I get it fixed?
Projector clocked 1000 hours roughly and working fine. However 1 day I tried to turn it own and seems completely dead. no blue light. fuse r al good
Does this projector have an automatic timer that doesn't allow it to turn on after a set number of hours (@ 1000)? If so, you may need to re-set the lamp-hour clock (as if you changed the lamp even though you didn't). Some machines require you to at least slide open the lamp cover to make it think that you changed it.
Feb 13, 2016 | ViewSonic PJD6251 3D DLP Projector
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
Tried a Kodak Extension remote cable and slide transport now inoperative
Take a closer look at the pins on the remote cable and the socket on the projector. Their are 5 pins on the plug. The top 2 pins are closer together than the bottom 2 pins. It is easy to rotate the plug 180 degrees and with little extra pressure, push it in. If the pin / plug interface is rotated 180 degrees, the remote control will appear non-functional. Check that first. Then try plugging the remote into the projector without the extension to eliminate a broken wire in the extension cord. Verify that the on-board cycle buttons will cycle the projector. If they do, and the projector won't work with the remote control, then there may be a open circuit inside the projector. You may need a factory-trained technician to help you with this one!! Good Luck !! Jim
Nov 06, 2012 | Office Equipment & Supplies
My son just purchased a Bell & Howell 2575C 16mm projector which seems in good working order; however, we cannot figure out how to turn on the light (the bulb appears to be fine)...we've threaded film,...
Chances are that if everything else seems fine and is coming on then most likely you have a bad bulb or it could be loose,make sure its fitted into the bulb holder assy good and snug,dont force it or you will break it at the base.Go to google and google your model number for the bell and howell projector and find out whats available and pricing.A middle of the road or average bulb should be suffice for what your doing.
Feb 09, 2011 | Bell & Howell Cameras
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Acer aspire one won't connect to projector
Hey,
On your desktop, right click, select properties.
now go to settings.
do you see screen number 2? select screen number 2 and check that the screen is enabled if not place a check on the checkbox and enable the monitor, now check the resolution and colors adjust them as you see fit, to move objects to the projector display drag them out from your laptop monitor.
Let me know if you need anything else.
Thanks,
Ekse
Jan 27, 2009 | Acer PD523 Multimedia Projector
Clock on my 2002 Subaru Forester does not work any more
This is a very easy fix! If your clock is above the rear view mirror, pop off the front of the housing with your favorite pocket driver, undo a couple of mounting screws, and unplug the clock. Reinstall new clock in reverse order. If your clock is on top of the dash, it just takes a little more elbow grease (push the housing towards the front of the car and then up) to get the housing off. Then, it's the same procedure as I described before. Good luck!
Dec 25, 2008 | 1998 Subaru Forester
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
Oregon Scientific DP200 Clock Radio Logo
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
