Question about Samson Resolv 65a Main / Stereo Speaker
Tweeter is cutting in and out - Samson Resolv 65a Main / Stereo Speaker
  • 3,400 Answers
Need to open up speaker and check connections on tweeter. Check closely on tiny wires from magnet(voice coil) to paper cone
Posted on Jan 04, 2011
Tweeter no sound but speaker no problem
In the most general, basic sense, I would be assuming that this is just one speaker and not 2 with this problem, or 3 or more.
Only way to get the ball rolling is pull the tweeter from the cabinet, checking to make sure all wires are connected at the tweeter and inside the speaker.
If that is the case, then you would need to determine if this is the tweeters fault, or its crossover (thing that divides the sound into whats right for the woofer and what the tweeter wants).
If you have a multi-meter, you would disconnect the wires from the tweeter, set the meter to ohms and touch a probe to each speaker terminal. No action means burned out tweeter, 100% action means burned out tweeter, a reading slightly less than the rating on the back of the tweeter (for instance an 8 ohm tweeter would show anywhere from 6 to 8 ohms on the meter) means tweeter is good.
If you have no meter then take the tweeter from the good speaker and swap in place of the bad one, making sure you respect + and - connections.Its a little risky this way,since if there is something wrong in the speaker it may hurt the good tweeter..(the meter is the safer bet). If it works, then you need a replacement tweeter, if not the problem is either wire connections inside the speaker, or something is wrong with the crossover.
Nov 03, 2014 | Audio Players & Recorders
My Bose l1 tweeter cuts out. any suggestions?
you are most likely turning it up too high so it cuts out to protect the speaker. Get bigger speakers.
Sep 04, 2013 | Quad 11L Main / Stereo Speaker
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
I have wharfdale atlantic 400se. The tweeter is no longer working. How do i work out if it is a cross over or the tweeter
If there was a traumatic high-volume event that preceded this problem, I'd guess the tweeter died.
If you can access the connections on the tweeter and you have an ohmmeter, you could disconnect the tweeter and measure across the the terminals. A shorted or open voice coil = dead tweeter. A measurement near the stated impedance is probably ok.
If you have NO ohmmeter, you could carefully connect the output of one amplifier channel directly to the tweeter and just scooch the volume upward slightly from silence while playing something with very little bass in it. If you hear it, the tweeter is alive.
Apr 18, 2011 | Wharfedale Atlantic 100 Rear Speaker
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
I have no radio plug in the car someone has cut it out . what wires are what?
there a lot of different options look at your RPO sheet and see if these are listed W54, W55, UL0, UL6,U62, W52, W53, UN0 with UQ0????
heres a basic radio orange=power (always hot), gray=inst panel dimmer, Yellow= hot with key on, Pink= antenna, gray-, tan+ LF tweeter, dark green-, light green+ RF tweeter BLACK= ground. the correct diagram will coincide with what option code you have, if you can look it up an dI will see what I can do.
Oct 14, 2009 | 1999 Pontiac Firebird
How do you install dome tweeters?
tweeters get installed almost like any other speaker. you pick a mounting spot, then mount them, or cut the hole for recessed tweeters, etc. run the wire to the closest speaker wire from your stereo, and just splice it in. you will however need some kind of crossover to prevent the low frequencies from being played through the tweeters. if you buy new tweets, they usually come with their own crossover, or there are a few different styles you can get.there are the passive crossovers, the ones that look like small boxes. there are also the inline filters. these are the ones that you splice into the positive speaker wire to filter out the low frequencies. and some aftermarket stereos come with some kind of filter or equalizer built in, depending on your model. what I would do is buy one of the inline filters for each tweeter. theyre inexpensive, and easy to install, and they work great. so basically, just mount the tweeter, run its wires to an existing speaker wire and splice it in, and install an inline filter on the positive wire for the tweeter. oh, one last thing. if your interior speakers are powered by an amplifier and not by the stereo, then just run the tweeter wire to the speaker outputs on the back of the stereo. too much power will definitely destroy any tweeter. good luck!
Sep 08, 2009 | Car Audio & Video
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Sound cuts out after a few minutes of operation
I blew the tweeter in my jbl stadium floor standing speaker. I would like to know how to remove the cover in order to replace the tweeter. I already purchased the tweeter and it is on the way. I don't want to damage anything in my attempt to remove it.
Nov 13, 2007 | RCA RT2760 System
Samson Resolv 65a Main / Stereo Speaker Logo
230 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
