Question about Microwave Ovens
Hi I have a goodmans GSS20 that has just stopped heating... it seems...everything else works...the light , turntable all the clocks etc it just does not heat but sounds as if it is running correctly...is it something that can be fixed like a fuse?
drumbanger
  • 1199 Answers
SOURCE: Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Posted on Jan 13, 2009
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: The microwave stopped heating. Everything else is working fine.
GE MAGNETRON REPLACEMENT
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Since it's within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Feb 15, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: I have a Whirlpool MH6130XEQ-0 microwave that doesn't heat food
If within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), the manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a Whirlpool-authorized servicer.
You can find your nearest Whirlpool/Maytag-authorized servicer here.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Mar 06, 2009
Clock,lights and turntable work but does not heat
Open the microvave discharge the capcitors.If you don't know then stop here and call pro .
Open it First check physically the nothing is burnt.I everything seems okay then, check the resistance of the magnetron and also the fuse.PLEASE DON'T TRY IF YOU DON'T KNOW HOW TO DISCHAGRE THE CAPACITORS.
Thanks
Please rate my work
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
Microwave does not warm but the grill works i have a Gss20 goodmans microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
k
Apr 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
