Question about Pioneer DVR-107D DVD±RW Burner
My hp pavillion dv6000 dvd is not working when i ckeck it on the device manager it was not there what should i do
  • 554 Answers
Just unjack the code and re connect it then start your PC, hope it will solve your problem
Posted on Jan 04, 2011
MY HP PAVILLION'S PORTS DON'T WORK, INTERNAL WIRELESS DOESN'T WORK AT ALL
Most of the laptops those are the common issues Wireless are not working, what i suggest is try to renistall the Driver for the wireless card then check it in the Device Manager, if it doesn't show in Device Manager the wireless card could be faulty.
How to check Device manager.
Start->Control Panel->Device Manager
Inside Device Manager look for Network Adapter and check if your wireless card is detected.
Apr 04, 2011 | HP Pavilion dv6000 Motherboard
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 04, 2011 | Pioneer DVR-107D DVD±RW Burner
My hp pavillion dv6000 dvd burner is not working when i check it on the device manager it was not there what should i do
download the drivers for this unit from manufactuers website and install them,then check your device manager again
Apr 27, 2010 | Pioneer DVR-107D DVD±RW Burner
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
Need drivers for hp pavillion dv6000 other devices pci drivers coprocessor sm bus controller running windows xp have yellow ?
You can find the drivers @ http://h10025.www1.hp.com/ewfrf/wc/siteHomeC?lc=en&dlc=en&cc=in&lang=en&os=228&product=top
Aug 27, 2009 | HP Computers & Internet
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Wrong region code
Go to device manager and then right click on properties, and then there should be a seciton on region code.
BTW< how the hell do i get rid of the underline?
Jun 02, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-107D DVD&#177;RW Burner Logo
50 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
