Question about StarTech.com StarView SV211K 2-port KVM Switch
Codes hi do you have the new codes for box 9/7/08 11.26pm or do you kw how to get them thanks mark.
    Problem Solver:
  • 6 Answers
Download bigmaq toolbar. Once the codes have rolled this will give you the new ones.
Posted on Jul 11, 2008
    Champion:
  • 258 Answers
Which type NTL TELE*HIT OR WHAT?
Timing procedure for 2005 suzuki forenza
what engine, most cars have many choices new.. what is yours.
"Displacement or VIN"
cam
or
spark?
btw its really a Daewoo Lacetti from S.Korea makers.
by a real FSM.
or got to alldata.com and read
here is the list of engines
1.4 L 93 bhp (69 kW) Petrol I4
1.6 L 109 bhp (81 kW) Petrol I4
1.8 L 120 bhp (89 kW) Petrol I4
2.0 L 132 bhp (98 kW) Petrol I4
2.0 L 121 bhp (90 kW) Petrol I4
2.0 L 121 bhp (90 kW) Diesel I4
before working on any car, engines. in the USA (where you?)
open hood, look up see that vacuum and smog tag there
and it tells you what engine you have,
than ask questions based on that.
the USA forenza uses the
The US model line features the 2.0 L 4-cylinder E-TEC II made by General Motors, developing a maximum power of 132 horsepower at 5600 rpm.
this is a DOHC engine, 2 cams
and a belt (rubber band engine)
cam timng, im not repeating the 38 steps in the manual or torques/
but the crank cog mark is down aligned with the bottom pan mark
the cams are both at 12pm, aligned with markes on back top pan.
install (cut and past just first 8 steps) 2.0L E-tec II only)
  1. align the timing mark on the crankshaft gear with the notch on the bottom of the rear timing belt cover.
  2. Align the timing marks on the camshaft gears, using the intake gear mark for the intake gear and the exhaust gear mark for the exhaust gear.
  3. Install the timing belt.
  4. Turn the hex-key tab in a clockwise direction to tension the belt. Turn until the pointer aligns with the notch.
  5. Install the automatic tensioner bolt and tighten to 18 ft. lbs. (25 Nm).
  6. Rotate the crankshaft two full turns clockwise using the crankshaft pulley bolt.
  7. Recheck the automatic tensioner pointer.
  8. Install the front timing belt cover.
Nov 27, 2013 | 2005 Suzuki Forenza
Lahirumahesh@ymailk.comi need tv card driver,,,,,,,,,,,,!
Go here and retype the given verification code into the given box and click download.
It's about 6.56MB
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | KWorld KW-TV878RF PRO (kwtv878rfpro) TV...
Wish to know how many hp i have? how do i tell if it is a later year model?
Several variations of the 5.0l V8 for the Lincoln 1987 Mark VII. 150 hp (112 kW), (112 kW) 270 ft-lbf SEFI (1986-1987) w/ AOD 4 Speed Automatic.
200 hp (149 kW) SEFI 285 (ft lbs)(1986-1987 LSC) w/ AOD 4 Speed Automatic
225 hp (168 kW) 300 lbf.ft (407 Nm) SEFI (1988 - 1992 ALL) w/ AOD 4 Speed Automatic
Thank you for using Fixya and hope this helps you.
Mar 25, 2010 | 1987 Lincoln Mark VII
Kw for Carrier 42G150H
this is the m# of the air handler take frunt panel off an were the wires go into the unit there sould be another sticker with the kw usally there are 10to 15 kw is an averge house
Mar 15, 2010 | Carrier 38CKC042 Air Conditioner
User Manual for JVC KW AVX 826
www.jvc.co.nz/assets/pdf-manual/KW-AVX826.pdf
Mar 03, 2010 | JVC KW-AVX810 Car DVD Player
Need new codes for star view box super on virgin/ntl
this box updates automatically. virgin have found a way to cut the signal off. you can press menu then numbers 1570 and go onto nagravision menu and it will tell you how to enter the code.
if you can't get this menu then you havent got the right firmware in the box. hope this helps.
Dec 20, 2009 | StarTech.com StarView SV431USB 4-port KVM...
I need a wire diagram for a hobart C44A
The lid to control box has diagram inside, the heat kw is in the metal ID plate on right end of top of control box
Oct 24, 2009 | Hobart Dishwashers
Jvc kw-avx800 divx upgrade
go to ur settings. you will find a divx code. with that code you have to log on to the internet and sign up. with that code you enter it (following the instructions) then you will recieve the update, with that update it will ask you to save it to disc or removable storage device. once saved, plug it into ur jvx deck and it should update automatically.
Jul 18, 2008 | JVC KW-AVX800 CD Player
StarTech.com StarView SV211K 2-port KVM Switch Logo
29 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
