Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do i change the ink cartridge in epson stylus nx515
  • 2692 Answers
SOURCE: How do you change ink cartridges on Epson Stylus cx 7800
Download your users guide for instructions.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58773&prodoid=56291070
Posted on Jan 20, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
cns assoc
  • 677 Answers
SOURCE: Replace cartridge screen stuck
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 01, 2010
n00h
  • 624 Answers
SOURCE: How to change ink cartridge on epson stylus nx515
Hello and Welcome to FixYa!
It is easy to change the ink cartridges yourself, but I'll give you a few advices first things first be cool and **** with the machine as there are such sensitive parts in Printers that if damaged, can not be repaired or replaced, making your machine useless and last but not the least, you should use the original Vendor's prescribed cartridges as this prolongs the overall machine's life.
I've provided a step by step Guide's link by the Vendor's Website with pictorial representations (That is divided into 4 steps, you can navigate through the buttons at the top left corner), you can find the link below.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Click here to be directed to the Guide
Posted on Jul 23, 2010
  • 50 Answers
SOURCE: trying to change ink cartridge on epson nx515
If your printer is out of ink, it will display the ink that you need to replace. Just open the lid and press the OK button.
If you want to replace an ink before it runs out, press the Setup button then go to Maintenance and press the OK button. Select "Ink Cartridge Replacement" or "Change Ink Cartridge", then press OK. You can now lift the lid then replace the ink.
Posted on Dec 07, 2010
Blurry orinting
go to printer settings and go to print configuration and run set up for new cartridges, to align cartridge heads.
Mar 13, 2014 | Epson Stylus NX515 All-In-One InkJet...
Have nx515 epson printer that will not print in black.Replaced with new still no black. Fix?
Do a head aliment page to test the nozzle operation.
The line on the test page should be in black and white.
Jan 15, 2014 | Epson Stylus NX515 All-In-One InkJet...
Color red not printing
Magenta ink of color cartridge finished, may due to more use of red prints. Replace cartridge.
Jun 22, 2013 | Epson Stylus NX515 All-In-One InkJet...
How to change the ink for an epson stylus nx130 printer
Replacing procedure only available if one or more ink tank "empty" or not recognized. Follow "how to..." at epson status monitor. but if you wish to replace, just turn on printer, unplug power chord while carriage moving. The carriage released from locking position, move carriage by hand to the appropriate position.
Jan 20, 2013 | Epson Stylus NX515 All-In-One InkJet...
How Do I Open The Ink Cartridge?
Let one of your friends do it so you do not have an issue greater than what you may already have.
Sep 03, 2017 | Epson Stylus NX515 All-In-One InkJet...
Trying to change ink cartridge on epson nx515 printer. how do I move the container out from under the printer to change it?
Nov 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to change ink cartridge on epson stylus nx515 ?
Concerned, Nooh
Jul 23, 2010 | Epson Stylus NX515 All-In-One InkJet...
I can't get the ink cartridge out. It is over to far and not in the opening. I have an Epson Stylus NX515
I solved the problem by using the read out on the printer, not by following the directions in the booklet
Jan 17, 2010 | Epson Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
839 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
