Question about Cell Phones
It says enter puk code - Cell Phones
S5830. Where can I get PUK code?
For Telstra
https://service.telstra.com.au/general/pinpuk/pukCodeRetrieval.html
go to this website and enter details
For Optus
Get your PUK over phone
have a pen and some paper handy
PREPAID
call 555
enter PUK code into handset
POST PAID OR PREPAID FROM OTHER PHONE
Dial 133 937 from another phone
select option 1
enter mobile number, and 4 digit optus privacy code if known
enter PUK into handset
if you dont know pin, hold line for further options
select technical support option
retrieve PUK code option
enter D.O.B. if requested
after a brief moment, your PUK code will be read out then repeated
Oct 07, 2015 | Samsung Galaxy Cell Phones
I forgot my puk code
Does this help? I have copied and pasted it from the www.att.com Support tab under the Wireless heading. I searched for Obtain PUK code.
Obtain a PUK Code
Instructions: When the error message "ENTER PUK CODE" is shown on the screen of the device:
  1. Log into myAT&T.
  2. Select Wireless from the myAT&T tab at the top of the page.
  3. Select Phone/Device.
  4. Click Unblock SIM Card.
  5. A new page will open, containing the PUK code for your phone. Enter the code on your phone's screen to unblock the SIM and create a new PIN.
Unblock SIM Card
  1. Enter the eight-digit PUK code on the phone, then press OK/Yes.
    Note: Some Motorola phone users need to enter **05* if "enter PUK" is not already displayed. After entering **05*, enter the eight-digit PUK code and press OK.
  2. Select a new PIN code, then press OK/Yes.
  3. Re-enter the PIN code, then press OK/Yes.
  4. If the codes were entered successfully, the phone is ready for use.
If the incorrect PUK code is entered 10 times in a row, the SIM card becomes permanently locked and a new SIM card must be purchased. If the device is requesting PUK2, call Customer Care at 800-331-0500.
Aug 06, 2014 | Apple iPhone 4 Black Smartphone
Puk blocked
For PUK codes, you can attempt 10x to enter the PUK codes in your phone. Once you enter incorrect PUK codes 10x,you'll recieve PUK blocked then what you need is to enter the PUK2. Make sure that you will enter the PUK2 correctly because if you enter incorrect PUK codes 10x,you'll recieve PUK BLOCKED error again. This time,you need to ask your service provider for SIM replacement.
Dec 11, 2011 | Samsung Cell Phones
Jow to unlock sim card
  • 'SIM Card Locked'
  • 'Your SIM card has been security locked. Please contact Customer Care for a PUK number.'
  • 'Code: SIM6'
  • 'Enter PUK code'
  • 'PIN code blocked. Enter PUK code:'
To enter a PUK code and unblock the PIN, follow these steps:
Important: You must call T-Mobile Customer Care for the PUK code. Entering the wrong code can permanently damage your SIM card.
  • Access the Phone application.
  • Enter the following string: **05*[PUK]*[new pin]*[new pin]#.
    • The brackets [ ] in the steps should not be entered. They denote placeholder information. For example, when you see [PUK], only enter the PUK code itself.
    • The command is executed when the pound # key is entered. You do not need to press the Send key.
    • The device pauses for 5 to 10 seconds while updating the new PIN.
  • Jun 21, 2010 | i-mate JAM Pocket PC
    What is PUK code
    puk stands for PERSONAL UNBLOCKING KEY which means if an invalid pin code is entered for three times (note that pin code is used to stop unauthorised use of sim) then u ll b asked to enter puk code. If wrong PUK code is entered 10 time thn ur simm ll b blocked permanently it means u can't use tat sim nemore. u can get ur PUK number by calling custemercare of ur operator.. thnx
    Oct 21, 2009 | Nokia 1661 Cell Phone
    Yh need me puk number
    What is a PUK code? A PUK code (Pin Unlock Key) is required when you enter an incorrect PIN 3 times. After entering the wrong PIN 3 times, the card will be locked and you will need to get a PUK code from your phone company to unlock it.
    What should I do if my phone says Enter PUK Code? How can I get a PUK Code? You can receive your phone's PUK code by calling your phone company Customer Care.. Once your PUK has been received, it will need to be entered into your phone to set a new PIN code. If the wrong PUK code is entered ten times in a row, the SIM card becomes invalid and you will need to purchase a new SIM Card. The phone will display "PUK blocked call operator".
    Jul 13, 2009 | Samsung SGH-D900 Cellular Phone
    Enter PUK code, asked for new PIN code, but then get "code error"
    my phone puk code got locked. i can unlock the puk code but it says enter new pin code. and when i verify it it says code error
    Jun 22, 2009 | Nokia E71 Smartphone
    I've tired to set the PIN code for my Nokia 6085 phone but I cannot. I've entered the PUK code but now it says, "Enter new PIN code:" What do I do? I've entered a code I wanted and other ones on my...
    HOLD ON!
    You may enter wrong PIN three (3) times only. After that your PIN will be blocked! To unblock, you need PUK. You can only enter wrong PUK ten (10) times. (This is as documented) After entering correct PUK, you will be asked for NEW PIN.
    So, when it says "PIN blocked. Enter PUK code", you must enter the PUK. If you correctly enter the PUK, it will asked for new PIN, by asking "Enter new PIN code:". Enter anything you want as your PIN. You will be asked to enter it twice (two times).
    From what I read from your post, you have done correctly, but you don't want to enter new PIN. There is no way SIM card/phone will use old PIN. The device doesn't know your PIN. So, you have to enter new PIN.
    Dec 25, 2008 | Cell Phones
    Entering PUK code on RIM Blackberry Pearl 8100
    The PUK code, (Personal unblocking Code) is used when you enter in a PIN wrong too many times. Not sure why you would need a PUK for inserting a indian SIM card. regardless the PUK code should be entered in when the AT&T SIM is inserted in the phone and asking you for the PUK. Also PUK's can change, you may need to call and get a more current one
    Dec 09, 2008 | RIM BlackBerry Pearl 8100
    Cell Phones Logo
    15 people viewed this question
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
