Question about Cameras
How can I get rid of the "memory card is write protected" in my screen so I can take a picture?
If your card is a SD type it may be that the little switch on the edge of the card has been pushed to the down "Locked" position.
It should be in the up position, nearest the edge with the contacts on.
Regards,
Ken.
Posted on Jan 04, 2011
When I try to take a picture it says "card locked". How do I get rid o f that?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 18, 2011 | Samsung Cameras
When I turn the camera on, I immediately get a blue screen with the message "Picture or video is protected." I can review what's on my memory card, but that's what I get when I want to...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 10, 2011 | Kodak EasyShare M863 Digital Camera
My K10 screen is showing "card locked" How do I get rid of the Card locked
Aug 01, 2011 | Photography
Screen reads "memory card is
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 24, 2011 | Nikon COOLPIX L18 Digital Camera
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Feb 12, 2011 | Nikon Coolpix L1 Digital Camera
When my camera is turned on, "write protect" comes on the screen, so I cannot take pictures. How do I get rid of "write Protect?"
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 26, 2010 | Cameras
I want to get rid of all the pictures on my SanDisk SDHC memory card. How can I do that?
Make sure it's not write protect enabled, insert it into the computer, and open "My Computer" (assuming you're using Windows previous to Vista).
Right click the drive icon that represents your SDHC, and click "format". If given any options, select "quick format" and click OK.
Within a minute or so, they're all gone.
If you want to keep ANY files on the card, and you just want to get rid of .jpg images, or whatever, you can perform a search on that drive for "*.jpg" exactly like that without the quotes. Once you've done that, it will find all those files, then you can right click and "select all", then right click again and "delete".
Aug 11, 2010 | SanDisk 2GB microSD Memory Card
What does 'Write Protect' mean and how do I get rid of it?
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
Apr 09, 2010 | General Electric A735 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
What does "memory card is write protected mean?" I can't take any pictures
when i turn on my nikon coolpix the screen says memory card is write protected what does that mean
Dec 07, 2008 | Nikon Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
