There are several reasons why a Lamber F92-EK model might accumulate water and spill it on the ground. Here are a few possibilities:
There might be a problem with the drain hose that connects the dishwasher to the sink drain. If the hose is clogged or not properly connected, water can build up inside the dishwasher and spill out onto the floor.
The dishwasher's pump or filter might be clogged, causing water to build up inside the machine.
The dishwasher might not be level. If it is tilted too much in any direction, water can accumulate in one part of the dishwasher and spill out when the machine is in use.
There could be a problem with the dishwasher's door seal. If the seal is damaged or not properly seated, water can leak out of the dishwasher.
To troubleshoot this problem, you might try checking the drain hose, pump, and filter for any issues, and ensuring that the dishwasher is level. You might also want to inspect the door seal to see if it is damaged or not properly seated. If none of these steps help, you might need to consult the manufacturer or a professional appliance repair technician for further assistance.
Did you saw the tea entering on the main motherboard? Did it worked after tea spilled in it? Water or any solution which contains water in it, which have short circuit on electronic boards, so it might had been damaged. Other important thing is, the computer motherboard contains microchip which is most likely to get damaged in small presence of small amount of water entering in it. So think twice about the amount of spill and then apply some idea, is the technician giving right diagnose, or you need another tech for this problem?
If power was NOT turned off immediately after the spill, it is likely electrolysis has eaten through one or more circuit trace(s). If power had been turned off right away and the unit dried it would have been OK. The unit will have to be taken to a shop and repaired. This could be an expensive repair.
If the mixer is working properly audio wise and only the clip LED's are lighting, the cost may be mostly labor to repair the circuit board damage.
Your camera might be damaged by the water spill. It's better to bring it on the nearest Authorized Canon Customer Service for immediate repair. Kindly browse link above for further assistance.
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
