Question about Simplex Kaba Ilco Unican 1000 keyless lock
How do I remove a unican L1000 lock from the door? I have the upper lock cylinder out, and used the spanner wrench to remove the ring on the non entry side. How do I get the handle off to remove the lock assembly?
Use the other side of the spanner wrench with the point and insert it into the hole in the inside sleeve and you will feel some spring tension.........push in the tool and pull the handle off at the same time.
Posted on Jan 26, 2011
  • BIG FLO Jan 26, 2011
    ps make sure the hole is at the 3 0 clock position for right hand and 9 0 clock for left hand if not you can spin the sleeve gently with channel lock pliers
  • 56 Answers
Inaert the pointed end of the spanner wrench into the hole in the lever hub (you may need t tighten up the rose temporarily to expose the hole), and depress a retainer to release the lever.
Once the lever is off, remove the two screws that were exposed when you removed the control cylinder and plate,
the lock should come off the door at this point.
Posted on Jan 06, 2011
  • gablesable Jan 08, 2011
    can you tell this process in words a kind of handy woman can understand. I don't know a rose, lever hub etc is. Thanks.
My lock is not working. How can I remove the mechanism from the outside
The mechanism is not removable for the outside, for that would defeat the purpose of the lock if any would-be entrant could just do that!
I am including a link to the grid of information for the L1000 lock, where you can find PDF links to the Manual, Parts List, and Tips. Tips has reprogramming and troubleshooting information.
In order to view PDF files, you will need to have Adobe Reader installed on your computer. There is a link to get Adobe Reader on the Literature Grid Page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
I found this instruction elsewhere on the FIXYA site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVER TIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:Spanner Wrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
May 23, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
pctuneup191
REMOVE THE KEY.
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Could you please help me. Thanks.
I believe you can find this to be relevant:
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Feb 14, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We have a Simplex LL101126D41 Combination lock and tried to change the code following the instructions for an earlier model (on that does not have the handle). Now the lock will not recognize the new nor...
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Feb 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
How do I change the code on the Kaba IIco Unican 1011 keyless lock?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good Luck!
Dec 21, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
The lock is staying open when the door is shuting i need to lube it but dont know how to open it up to do so
The installation instructions for simplex keyless locks can be found using this grid on the KABA website. You will need Adobe reader to view-- these are PDF files:
Dec 17, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Forgot code to Unican L1000 lock. How can you reset code?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Oct 29, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
3,257 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
