Question about Motorola Mobility E815
E815 I have and white screen, but still can read the screen if you turn it at an angle. It's like the brightness is too high, but can't adjust.
  • Anonymous Jul 20, 2008
    I also have the white screen of death. I cannot read anything from the screen but the phone stills works. I just have to have the operational keys memorized. How can I fix?
  • 66 Answers
The phone has a flex cable that connect the bottom of the phone to the top. that cable need to be replaced. contact you local cell phone repair tech or you can contact www.fixphonenow.com . they do this repair for $40.
Posted on Nov 22, 2008
I'm not able to adjust screen brightness on my kindle - there is no lightbulb icon in the tool bar. I'd like to read at night, is there a way to adjust screen brightness?
Is the Kindle a Paper White version, or akin to the original Kindle version? If so, there is no backlight, so no screen brightness adjustment. You'll have to do the screen brightness adjustment like you would for a book.
Nov 01, 2015 | Amazon Kindle
Computer screen looks overly bright
please adjust Brightness and contrast at comfort level. if problem persist reinstall graphic drivers.
Jan 22, 2014 | Dell Inspiron One 2020 All-in-One Desktop
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
MY E815 screen has weird signs
Check this link to see info about your phone.
Apr 25, 2008 | Motorola Mobility E815
Replaced bulb-now very bright white display
go to menu and to screen and adjust brightness and contrast
Jan 27, 2008 | Toshiba TDP-S20U Multimedia Projector
Main screen blank
Same problem here...must be a bug with the phone or has to do with DST..Appears all E815's will not work.
Oct 23, 2007 | Motorola Mobility E815
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Brighteness
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus. I spend 30 minutes popping the case apart just to find that I could not access the adjustment screws from inside. Lo and behold, they made them easily accessible from the outside. On a side note, I have never seen a TV designed as poorly as this on the inside. You have to literally reach in and unplug things just to get the back off. All the electronics save the tube itself are mounted to the rear chassis. On all other TV's I've seen (taken apart, rather), all the electronics are in the FRONT part of the chassis so that they move WITH the tube.
Sep 23, 2006 | JVC AV-27530 27" TV
Motorola Mobility E815 Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
