Computers & Internet Logo
Posted on Jan 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convert 15,700 naira to us dollar - Computers & Internet
Iminathi Dlamini
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 12 Answers
  • Posted on Aug 29, 2018
Iminathi Dlamini
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
12
Questions
0
Helped
3587
Points
55
Anonymous
Level 3:
  • Master 3,400 Answers
  • Posted on Jan 04, 2011
Anonymous
Master
Level 3:
Answers
3400
Questions
Helped
986163
Points
10767
Try this -> http://coinmill.com/NGN_USD.html
1helpful
I have a hard time understanding the Ford towing chart. Can someone tell me if a 2018 Ford F250 can tow a 16000lb fifth wheel?
The chart that I see shows that a F-250 can tow between 12,300-13,300 lbs. A F-250 Super Duty gas can tow 15,700 lb gooseneck, a diesel can tow 18,500 lb.
1) A trader bought 45 dozen items for 2700 naira. If 15% of the items got destroyed, what should be the cost per item to make a profit of 265? 2) A woman bought 200 mangoes for 800 naira she discovered...
Answer A:
45 dozen: 12 x 45 = 540
Destroyed: 15% of 540 = 540 x (15/100) = 81
Remaining: 540 - 81 = 459
A profit of 265 means that 459 items must sell at 2700+265=2965 naira or 2965/459=6.46 naira approximately.
Cost per item = 6.46 or 6.5 naira approximately
Answer B:
Cost = 800 naira
8 spoilt. Remaining = 200 - 8 = 192 OR 16 dozen (12x16=192)
Selling price: 60 naira per dozen = 60 x 16 = 960 naira
Profit made (selling price - cost price) = 960 - 800 = 160 naira. Percent profit = Profit/cost x 100 = 160/800 x 100 = 20%
Percentage profit = 20%
2answers
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
I need my puk number
Hi
Kindly call up your celluler provider nad they will [provide you with PUK code.
Thanks.
Mar 26, 2010 • Nokia 1100
1helpful
Suppose 1011 amt convert in words like 'One
Hiii
  1. Start Microsoft Excel.
  2. Press ALT+F11 to start the Visual Basic Editor.
  3. On the Insert menu, click Module.
  4. Type the following code into the module sheet. Option Explicit
    'Main Function
    Function SpellNumber(ByVal MyNumber)
    Dim Dollars, Cents, Temp
    ' String representation of amount.
    ' Position of decimal place 0 if none.
    ' Convert cents and set MyNumber to dollar amount.
    Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _
    "00", 2))
    End If
    Count = 1
    Temp = GetHundreds(Right(MyNumber, 3))
    Else
    MyNumber = ""
    End If
    Count = Count + 1
    Loop
    Select Case Dollars
    Case ""
    Case "One"
    Case Else
    End Select
    Select Case Cents
    Case ""
    Cents = " and No Cents"
    Case "One"
    Cents = " and One Cent"
    Case Else
    Cents = " and " & Cents & " Cents"
    End Select
    SpellNumber = Dollars & Cents
    End Function
    ' Converts a number from 100-999 into text
    Function GetHundreds(ByVal MyNumber)
    ' Convert the hundreds place.
    If Mid(MyNumber, 1, 1) <> "0" Then
    Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
    End If
    ' Convert the tens and ones place.
    Result = Result & GetTens(Mid(MyNumber, 2))
    Else
    Result = Result & GetDigit(Mid(MyNumber, 3))
    End If
    GetHundreds = Result
    End Function
    ' Converts a number from 10 to 99 into text.
    Function GetTens(TensText)
    Result = "" ' Null out the temporary function value.
    If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19...
    Select Case Val(TensText)
    Case Else
    End Select
    Else ' If value between 20-99...
    Select Case Val(Left(TensText, 1))
    Case Else
    End Select
    Result = Result & GetDigit _
    (Right(TensText, 1)) ' Retrieve ones place.
    End If
    GetTens = Result
    End Function
    ' Converts a number from 1 to 9 into text.
    Function GetDigit(Digit)
    Select Case Val(Digit)
    Case 1: GetDigit = "One"
    Case 2: GetDigit = "Two"
    Case 3: GetDigit = "Three"
    Case 4: GetDigit = "Four"
    Case 5: GetDigit = "Five"
    Case 6: GetDigit = "Six"
    Case 7: GetDigit = "Seven"
    Case 8: GetDigit = "Eight"
    Case 9: GetDigit = "Nine"
    Case Else: GetDigit = ""
    End Select
    End Function
Hope this will solve ur problem
Regards.
G'Day
2helpful
My sim card {07062123757} requires a puk number to be unlocked
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK code (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. so contact your service provider
Get your PUK code from your provider.Call mtn customer care num 180 for nigeria, they'll give you your PUK... and , write it down incase you lock up your phone again.
Each device has a unique PUK that u can use when the sim is locked!
How to convert numbers into words in MS excel?
Option Explicit '**************** ' Main Function * '**************** Function SpellNumber(ByVal MyNumber) Dim Dollars, Cents, Temp Dim DecimalPlace, Count ReDim Place(9) As String Place(2) = " Thousand " Place(3) = " Million " Place(4) = " Billion " Place(5) = " Trillion " ' String representation of amount. MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none. DecimalPlace = InStr(MyNumber, ".") ' Convert cents and set MyNumber to dollar amount. If DecimalPlace > 0 Then Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _ "00", 2)) MyNumber = Trim(Left(MyNumber, DecimalPlace - 1)) End If Count = 1 Do While MyNumber <> "" Temp = GetHundreds(Right(MyNumber, 3)) If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars If Len(MyNumber) > 3 Then MyNumber = Left(MyNumber, Len(MyNumber) - 3) Else MyNumber = "" End If Count = Count + 1 Loop Select Case Dollars Case "" Dollars = "No Dollars" Case "One" Dollars = "One Dollar" Case Else Dollars = Dollars & " Dollars" End Select Select Case Cents Case "" Cents = " and No Cents" Case "One" Cents = " and One Cent" Case Else Cents = " and " & Cents & " Cents" End Select SpellNumber = Dollars & Cents End Function '******************************************* ' Converts a number from 100-999 into text * '******************************************* Function GetHundreds(ByVal MyNumber) Dim Result As String If Val(MyNumber) = 0 Then Exit Function MyNumber = Right("000" & MyNumber, 3) ' Convert the hundreds place. If Mid(MyNumber, 1, 1) <> "0" Then Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred " End If ' Convert the tens and ones place. If Mid(MyNumber, 2, 1) <> "0" Then Result = Result & GetTens(Mid(MyNumber, 2)) Else Result = Result & GetDigit(Mid(MyNumber, 3)) End If GetHundreds = Result End Function '********************************************* ' Converts a number from 10 to 99 into text. * '********************************************* Function GetTens(TensText) Dim Result As String Result = "" ' Null out the temporary function value. If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19... Select Case Val(TensText) Case 10: Result = "Ten" Case 11: Result = "Eleven" Case 12: Result = "Twelve" Case 13: Result = "Thirteen" Case 14: Result = "Fourteen" Case 15: Result = "Fifteen" Case 16: Result = "Sixteen" Case 17: Result = "Seventeen" Case 18: Result = "Eighteen" Case 19: Result = "Nineteen" Case Else End Select Else ' If value between 20-99... Select Case Val(Left(TensText, 1)) Case 2: Result = "Twenty " Case 3: Result = "Thirty " Case 4: Result = "Forty " Case 5: Result = "Fifty " Case 6: Result = "Sixty " Case 7: Result = "Seventy " Case 8: Result = "Eighty " Case 9: Result = "Ninety " Case Else End Select Result = Result & GetDigit _ (Right(TensText, 1)) ' Retrieve ones place. End If GetTens = Result End Function '******************************************* ' Converts a number from 1 to 9 into text. * '******************************************* Function GetDigit(Digit) Select Case Val(Digit) Case 1: GetDigit = "One" Case 2: GetDigit = "Two" Case 3: GetDigit = "Three" Case 4: GetDigit = "Four" Case 5: GetDigit = "Five" Case 6: GetDigit = "Six" Case 7: GetDigit = "Seven" Case 8: GetDigit = "Eight" Case 9: GetDigit = "Nine" Case Else: GetDigit = "" End Select End Function To use this UDF push Alt+F11 and go Insert>Module and paste in the code. Push Alt+Q and save. The Function will appear under "User Defined" in the Paste Function (Shift+F3).
Grand Canyon Tech
Grand Canyon Tech
