Question about Motorola Mobility ROKR E6 Smartphone
Sd card pops out of its slot..Does not click shut
  • 554 Answers
The tooth of the SD card may be damaged, try using a different SD card
Posted on Jan 04, 2011
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Cannot find map data files
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 06, 2010 | Computers & Internet
The micro sd card keep popping out
may be you put it in the wrong way.
May 14, 2010 | Cell Phones
Memory card won't stay in the slot, won't read.
service camera at Nikon. mechanical SD card lock failure
Nov 24, 2017 | Nikon Coolpix S210 Digital Camera
GPS CAN NOT FIND MAP DATA FILES
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
  5. A menu pops up.
  12. Click "Start"
Good luck.
Apr 17, 2009 | Nextar X3-03 Car GPS Receiver
MY GPS WANT NAVIGATE AT ALL IT WANT EVEN BRING UP MAP AT ALL CAN ANYONE HELP ME
You will probably need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  5. A menu pops up.
  12. Click "Start"
Good luck.
Apr 15, 2009 | Nextar X3-03 Car GPS Receiver
When i push to navigate it says the file does not exist
  5. A menu pops up.
  12. Click "Start"
Good luck.
Mar 30, 2009 | Nextar X4-T Car GPS Receiver
Everything but the navigation (X4-T) on my GPS works...any suggestions?
  5. A menu pops up.
  12. Click "Start"
Good luck.
Mar 25, 2009 | Nextar X4-T Car GPS Receiver
I like to up grade my sd card on my magelian 360 roadmate E-mail as follow:bojo9335@verizon.net
To change the sd-card do the following:
Peel back the rubber gasket to expose the SD card slot. Do not
completely remove the rubber gasket.
Push the SD card until you hear a click. Do not attempt to pull
the card out of the slot
Remove the SD card from the slot.
To Insert new SD Card
Insert the SD card into the slot (Do not force
the card into the slot.)
with the metal contacts going in
first and the beveled edge to the left.
Close the rubber gasket.
Mar 22, 2009 | Magellan GPS
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
Motorola Mobility ROKR E6 Smartphone Logo
23 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
