Question about Car Audio & Video
I need a wiring diagam for a pioneer avh-p4050dvd i have misplaced mine and want to install in another car
hogan doan
  • 227 Answers
SOURCE: pioneer avh-6400cd
Go to Pioneer site to down load the hardware manual for it, it should include the wiring diagram. Good luck.
Posted on Mar 23, 2008
  • 18 Answers
SOURCE: bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Posted on Jun 10, 2009
rteemon
  • 578 Answers
SOURCE: trying to install need wiring diagram
wht vehicle
Posted on Jun 26, 2009
SOURCE: NEED WIRING DIAGRAM
hope this helps,......http://www.nodevice.com/user_manual/pioneer/car_multimedia/avh-p5700dvd.html
Posted on Aug 01, 2009
pctech1
  • 1940 Answers
SOURCE: help i need a wiring diagram for a pioneer
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
Posted on Jan 12, 2010
My pioneer avh-x3500bhs keeps resetting itself
Mine does the same thing, its not a wiring issue as I put a different Pioneer Head Unit in its place and the problem went away. I put it back and the problem returned
Jan 16, 2014 | Pioneer AVH-P4000DVD Monitor
My Pioneer AVH-P1400dvd wont cut on after installing it
Did you make sure you connected the Blue wire to the pioneer its the remote to the car when the car is on the device will be on if you don't connect this wire the device will stay on
Dec 28, 2013 | Pioneer AVH-P1400DVD
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
Jan 11, 2013 | Car Audio & Video
Help i need a wiring diagram for a pioneer avh-p5700dvd to connect to a wiring harness and a tr-7 output module
Jan 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
My Pioneer AVH-P4100 DVD just beeps...
could it be a ground or is the ant. plugged in
Aug 20, 2009 | Pioneer AVH-P4100DVD Car DVD Player
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Sep 10, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
359 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
