Question about Acer NSK8458AN Keyboard
My left touchpad button has lost it's sensitivity and I suspect there is dirt in it. Can I prise it off to clean under it?
2 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: touchpad has stopped working, can you help?
Hi there don't worry. Its disable that's why not working. Please press FN+F7 and try. The symbol on your keyboard is below. Just press FN+ below mention symbol. Thanks.
Posted on Apr 07, 2010
My cursor keeps jumping and moving the letters in my emails.
Step 1:
If you are a frequent user of a notebook or netbook computer, then you likely use a touchpad to navigate your computer's on-screen cursor. However, there are a number of issues that can cause your cursor to seem jumpy or unresponsive. To find what is causing these issues, you can troubleshoot both your hardware and your operating system and find a solution to the problem.
Turn your computer off and then clean your touchpad. Dampen a clean cloth with some isopropyl (rubbing) alcohol and then pat the pad dry with a paper towel. Even a small stain or sticky spot can throw off your touchpad's sensitivity, so it is vital that the pad remain clean of all extraneous substances. Re-calibrate your touchpad. Go to the hardware section of the "Mouse" utility (in the Control Panel) and find the device settings. There should be an "Advanced Settings" or "Calibration" utility under this tab. Follow the prompts to calibrate your touchpad for maximum efficiency. Use manual troubleshooting wizard. If you suspect that your computer's software or drivers are at fault, run the manual troubleshooting wizard. Go to the "Mouse" utility (in the Control Panel) and then go to the "Hardware" tab. Select your touchpad and then click on the "Troubleshoot..." button. Follow the prompts to troubleshoot software issues that could make your touchpad jumpy. Reduce cursor speed. In the "Mouse" utility, go to "Pointer options" and reduce the speed. This will prevent the cursor from going too fast when you move your finger on the touchpad, which could be the source of the "jumpy" effect.
Feb 15, 2013 | Toshiba Computers & Internet
Jumping cursors and letters
Step 1:
Feb 15, 2013 | Toshiba Satellite Computers & Internet
The cursor jumps around on my ASUS K501J notebook.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 08, 2012 | ASUS K50IJ Notebook
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Left button of the Asus Eee 900 is not working?
I guess you mean the left touchpad button. With my 900 that happened after only 4months extensive use. Reasons could be dirt in the microswitch under the button or broken contact of switch on MB. To exclude software problem, switch buttons in touchpad driver panel and see if the right button function is not working when pushing the left button. If you don't want to open your eeepc to clean or fix, activate the tapping option in the touchpad options and asign a "2taps with one finger" to a left mouse click for replacement. I work with that for almost 2 yrs now without ever using the left button again. Should you just switch buttons, be prepared that the right button might leave you too in a while.
Take care,
Juan
Jan 17, 2011 | ASUS Eee PC 900 PC Notebook
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
Touchpad has stopped working, can you help?
Apr 07, 2010 | Acer Computers & Internet
My touchpad has lost sensitivity. How do I fix it?I have to use the right.left bars underneath once I make a selection.
It seems that the sensitivity for the touchpad has dipped. Hoping that you might be using Synaptic's touchpad.
See if this helps..
1.. Click Start then click Control Panel.
2.. Click Printers and Other Hardware then click Mouse.
3.. Select the Device Settings tab.
4.. Highlight Synaptics TouchPad in the list and click the Settings
button.
5.. Click the plus sign next to Sensitivity to change the sensitivity settings of the touchpad.
If you are not getting any positive result from changing the settings, you can uninstall and re-install the drivers for the same and then check it once again. If all fails, this leads to the result that the touchpad is itself damaged and you need to replace it.
Cheers!
Apr 04, 2010 | Computers & Internet
My right click button on my touchpad responds sometimes. It is sporadic. It is a Acer Travelmate 2480 notebook. Any suggestions? Where is a reliable place to get a new touchpad etc. Thanks
This could be as simple as dirt, crumbs or hair etc that is basically stuck under the right click button.
Turn the laptop on it's side and get a clean, dry paintbrush. Gently tap around the touchpad area with the back of the brush to dislodge any foreign objects that maybe stuck under the button. Then use the bristle end to clean around and under the buttons.
Hopefully this should resolve the problem for you.
If not then you will be able to get a replacement touchpad for your laptop from websites like eBay for example. All you have to do is search for the touchpad by the laptop model number and are fairly cheap to purchase.
Regards.
Feb 18, 2010 | Acer TravelMate 2480 PC Notebook
Advent 5401 left touchpad button broken
Had a similar problem a couple of months ago, The left button started playing up, not working with every mouse click, it gradualy got worse till it was nearly unusable.. I suspected that the microswitch under the silver button had some dirt in it. After taking a deep breath I removed the battery and the screws that hold the case lower and upper halves together and was able to seperate the case front by about 3/4 of an inch. Then using a contact cleaner Servisol Super 10 and supplied flexible straw I squirted cleaner into both mouse click buttons. After waiting for cleaner to evaporate and resecuring case halves and replacing battery I switched on .... The button works 100%..
Feb 02, 2010 | Advent Netbook
Acer NSK8458AN Keyboard Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
