Question about Brother HL-4040CN Laser Printer
I rec'd a fax this morning w/ a 2" solid black line on the right hand column. I also noticed that the screen reads "drum end soon." Are those two things related? And, what is "drum end soon" and what do I do about it? Thanks! - Monica Graham, Director of Admissions, Maryvale Preparatory School
    Sergeant:
  • 174 Answers
You replace an original print cartridge. (Make and the model No.)
Both the problem is same, because of the damaged / faulty drum of right
side the black line is prominent.
Posted on Jul 23, 2012
  • 215 Answers
Print out an internal report of some kind from the control panel. if line/band is still there, then drum most likely is the problem. sometimes however, that band can originate from the sending fax. "drum end soon" means your drum has come close to the 17,000 prints it is rated for and you need to get a DR110 drum unit. the drum unit is what your 4 toners sit in.
hth,
razors
Posted on Jan 14, 2011
I just replaced my Muratec F-305 drum DK 203OUS with new one and the red warning dot comes up and says "Drum near end" with the new drum. What is wrong?
Yes, the display was saying "drum near end"....it was not saying to replace the drum,... you only replace the drum when it says "replace drum"....right now you have b;own the fuse in the new drum because you replaced it TOO SOON. You will have to find someone to replace the mini-fuse in the drum cartridge...it will still be ok...but soon you will not be able to print on the machine,,,READ THE USERS MANUAL.
Nov 16, 2010 | Muratec F-300 Fax
Black solid line on the right hand of page when
Hi, remove the black drum and clean the corona wites and drum GENTLY with a LINT FREE CLOTH. If there uis no change in the print quality you may need to replace the black drum. Hope this helps
Feb 18, 2010 | Epson Aculaser C1100 Printer
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Solid black lines on the right side of page
Try sliding the blue tab on the drum unit side-to-side. If that does not cure it, you need a new DRUM UNIT
Oct 02, 2009 | Brother IntelliFAX 4100 Laser Fax
95% of copy or sent fax black
You need a new cis unit, that is the scan assembly. Some of the pixels are burned out. Exposure settings won't help at all...
Jul 24, 2009 | Brother IntelliFAX 4100 Laser Fax
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
When we recieve Fax, the paper is very dark
We had the same problem and we switched out the drum and now the faxes are very clear except for a solid black line going down the right side of the paper.
Mar 14, 2009 | Brother IntelliFAX 2800 Laser Fax
2" BLACK LINE
1- itis on the Scanning unit open and look for a thin strip of glass, clean
2-the scanning unit is bad
Assuming it's only on Outgoing Fxs and not incoming as well ( that would indicate the drum)
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Brother HL-4040CN Laser Printer Logo
163 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
