Question about Thomson 40KW612S 40 in. TV
The TV was working all right last sunday ( 02.01.2011). The day after it didn`t start. The redlight lamp turn quickly to yellow, green and then red, did the same 3 times and then only red flashing light. It was the same operation everytime I tried to start it. I live in Norway, and here is few who repair Thompson Projection TV. What do you think is wrong?? The lamps?? Can i fix it myself ??
5 Suggested Answers
okcfirewall
  • 80 Answers
SOURCE: Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Posted on Jul 20, 2009
easyab
  • 132 Answers
SOURCE: Hi, I'm looking for supplier> 1 projection lamp
50DSZ644 is an LCD Flat Panel TV, there is no replacement lamp. Here is a link to RCA TV Lamps and associated model numbers.
easyab@hotmail.com
Posted on Feb 11, 2011
SOURCE: thompson 52jw643 is stuck in standby, when switch
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Posted on Aug 16, 2011
SOURCE: Thomson 44jw642s problem with starting.
Verify capacitor cp150 (2200uF/16V)
JLopes
Posted on Nov 08, 2011
50hm66
Some possible reasons include: New lamp is generic and or has a issue----excessive dust or dirt inside the unit on fans etc.
Some of these units had a feature in the menu for quick on where lamp is lit at low level all the time---this shortens the life of the lamp etc
If you did not have this issue before lamp replaced I would suspect a generic cheap bulb may have been used instead of the Toshiba cartridge / lamp combo which costs more.
With the quick on if the set has it normal time is 20 seconds for screen to light----set WILL DETECT IF LAMP IS NOT COMING UP FAST ENOUGH OR BRIGHT ENOUGH.
Generic lamps (cheap) will never be as bright or last a long as a OEM lamp unit.
Just some thoughts based on your question.
Aug 28, 2012 | Toshiba 50HM66 52" Television
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Thomson 40KW612S 40 in. TV Logo
111 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
