Question about Gaggenau EB388 Electric Single Oven
Door come off
Thank you chad fix it, that was spot on, we didnt think off the nail thing, genious! xxxx
    Scholar:
  • 148 Answers
Glad I could help
Posted on Jul 09, 2008
Is there a way to fix what seems to be a sprung hinge?
If you are saying the door no longer returns to its upright position on it's own than the spring broke, the hinge is fine so long as it travels the same path.
Just google: "oven door spring XXXX" where the x's are your model number.
Apr 04, 2015 | Ovens
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
We are having a difficult time getting the door back on the oven. Can you give us a tip on how to keep the hinges from snapping back when we are trying to hook the himges back onto the rods?
Passing on the solution. Some other blogger helped me, so I hope this will help you. Mine is a Kenmore Gas range, but the hinges might be similar. They are fixed on the door, not on the range. Get a couple sturdy nails or similar items and keep them in your hand. Use your foot to push the hinge all the way down, as if the door were fully open. You should see a hole in the hinge, in which to insert the nail to hold the hinge open. Repeat on the other hinge. Carefully lift the door in place and set the hinges so they hook onto the latches properly. You should be able to open the door a bit to take the tension off the nails. remove the nails, and that should be it. Even if your hinges aren't the same as mine, the principle seems to apply. My problem (maybe yours) was that I couldn't open the hinges and keep them open when trying to replace the door. They just would snap closed. Very frustrating.
Jan 23, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I remove the oven door to fix the inner glass that has come apart
Hi, The picture I looked up is very poor but, I believe you will need to open the door all the way. Look at the hinge and see if there is a small hole that you can insert a small nail into so that the door will not close all the way. Once you get this done, try closing the door and lift up at the same time. This should release the hinge inside the wall and allow it to pull off. Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Cant get the oven door back on
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Jan 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
I have a Whirlpool Oven #SF395LEE* (RB26126336) accubake Systems. Today the oven door came off and I need to know how to put it back on. I do not see this over on your list. Can you help? Thank...
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 13, 2008 | Whirlpool RBS245PDS Electric Single Oven
Just wanted to say THANK YOU, THANK YOU!
a great reply like this is thanks enough we rarely get them but its no big deal most of us are here to help but you can post to this message and rate me after wards that helps my rating four boxes is great but thank you for your kind reply
Jun 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door came off
Just found this posted by tech17 (THANK YOU SO MUCH!) and it worked!
POSTED BY TECH17:
i posted the solution under premium problems i don't know how that works but what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
May 11, 2008 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RF396LXE2 Oven
Whirlpool oven door
Push the hinges out till they click once. At this point, get your nails or screws ready. Use a screw driver and wedge the hinges further apart. When you see the hole in the hinge appear, put the nail in it to hold it open. With both done, drop door in place; open door slightly, and remove nails.
Oct 17, 2007 | Ovens
Gaggenau EB388 Electric Single Oven Logo
155 people viewed this question
Top Gaggenau Ovens Experts
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
