Belkin F5D7234-4 Router Logo
Posted on Jan 04, 2011
I have a belkin g router and want to connet to ma pc via the lan connection. it's cable network so how can i connect directly without a modem?
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 05, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
1381
Points
38
Helping business and IT leaders, just like you, to take their own path Great inspiration comes from individuals who dare, against the odds, to make their dreams come true. Every day, around the world, more and more individuals are taking that first step.
From the day we created our first computer, we've delivered something with a promise: the spirit of individualism. We realised that the best way to support small and medium-sized businesses is to become a true partner who supports their success with the right technology solutions.
So whether you're growing a successful business or innovating the business through technology, when you choose Dell, you're choosing exactly what you want to empower you.
It's not just making your own way; it's taking your own path.
Ten Technology Tools That Make Your SOHO
Productivity Soar
Olive Nexus Wireless Router Portability- Like smart moves? Why leave your office behind? The sleek 802.11b/g EVDO/HSPA based Olive Nexus enables you to log in a group while on the go. In other words, now your office is so smart that your whole department can log on from a beach in the Bahamas or a ditch in Dover!
Power - Nexus's unique 1700mAH Li-ion battery gives wings to your router and nixes the need for external power supply. And its miniscule electricity consumption coupled with a back up time of 1.5 hours mean the power is with you always!
Multiple Connectivity - Today, you are definitely not where you were yesterday and tomorrow you will be in a different place from where you are in today. That's why the V-R9 Olive Wireless Travel Router comes with multiple connectivity options like -
EDGE/3G/1X/EV-DO USB modem
Data enabled cell phone
Ethernet (ADSL, Cable, WiMAX)
so that whenever you want to get connected - you can, from wherever you are!
Multi User - Anything that is fun under the sun from soccer to tango requires more than one participant! Why should it be any different while you are on the internet? The V-R9 Olive Wireless Travel Router sees to it that you and your colleagues or your beer buddies can log in all together even when you are on the go!
Pocket Size- Now that the 'Black is beautiful' phrase has gone out of fashion, the 'Small is Beautiful' has taken its place. Keeping up with the times, the mighty V-R9 Olive Wireless Travel is tiny enough to be a snug fit in your pocket!
Back to SOHO Solutions Table of Contents
I bought a Belkin 'Play' router to provide wireless internet connectivity from my CLEAR modem. I can't get the router to speedtest at half the speed as being directly connected (via ethernet cable) to the...
Use an Ethernet cable from the CLEAR modem into the WAN (or 'Internet') port on the Belkin.
Take a close look at the 8 coloured wires at each end of the Ethernet cable.
The 8 wires must be coloured in the _same_ order at both ends.
Be sure that you have a 'CAT-5' or 'CAT-5E' cable, not a 'CAT-3' cable, which is much slower, over long distances.
Use another Ethernet cable from one of the (three? four?) 'LAN' ports on the Belkin to the network-port on your computer. Again, check that you have a "straight-through" cable, not a "cross-over" cable.
Turn the CLEAR modem off.
Turn the Belkin off.
Turn your computer off.
Turn the CLEAR modem on, and wait until its lamps settle-down to a consistent pattern.
Turn the Belkin on, and wait until its lamps settle-down to a consistent pattern.
Turn your computer on, and let it boot.
You now should have Internet access.
Note that the router "dynamically" shares the Internet connection.
If there are 4 'LAN' ports, then each of the LAN ports gets as much speed as it needs;
you do not have a 25/25/25/25 split, unlike cutting-up an apple-pie to feed 4 people.
Run a "speed-test" on your computer, and you should be getting as much speed as you are paying for. Having the Belkin in the "middle" of your network should *NOT* slow-down the speed-test at all.
Hi I am using reliance broadband. They have
Easy, if your modem is connected to your computer right now and internet is working all you need to do is connect your LAN line to your belkin router. the connection should say input, or Internet. after that you will need another LAN wire (These look like telephone cables but the jack plug is larger and will only fit a lan connection on your router or computer) Connect the second wire to the line 1 or outout 1 from your router, to your pc in the slot where the other cable was connected. your internet signal should work.... on your mobil find any available network and log in to your belkin router.
that should do it.... if you haven't set up your internet connection, do that first by installing the drivers for the modem provided by your provider and then complete the process above.
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Cant connect wired to my router modem? it works via wireless
Do you know for sure that:
A) The cable you are using is correct? Have you used it elsewhere?
B) Is the network connection enabled? Goto Start, Network Connections and look at the status of the connection. It may just be disabled or miss-configured.
27helpful
2answers
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Thanks
Belkin (F5D7633-4) Wireless Router and SpeedTouch 360
I have solved this issues. I simply had to change the VPI/VCI values which i have obtained from my ISP. These value differ from one ISP to another.
Thanks for all the people tried to help me!
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
