Question about Amcor PLM-14000E Portable Air Conditioner
The air conditioning part of the unit will not work, although i can set the clock and the timer, it does not react to any of the other buttons. I have cleaned the filter and ensured it has been replaced correctly as well as emptying the over flow pipe.
Cuisinart dgb900bc. Set timer to brew at 5 45. Have for many years. Last two nights at 5 45 clock goes to 12 00 AM. Does not come on automatically. Turn on manually and brews coffee as great as usual....
I would assume that the chip/timer unit has failed in the unit. Not sure you want to try to disassemble the coffee maker to get at it. Have you tried reversing the a.m. to p.m. (thus the clock would read 5:45 p.m. at 5:45 a.m.) settings and seeing if the machine would brew the coffee normally? (although I seriously doubt this will work, but...)
Jun 21, 2014 | Coffee Makers & Espresso Machines
How do we reset our telstar air contioning wall unit remote model #HYK-07...we changed the batteries but now it doesn't work
Hi Diane,
Your remote control has a reset button in front just below the timer button key. Press it using a pointed material like a paper clip to make it functional reset.
Let me know if the remote control still not functioning to assist you further.
Jdvillanueva
Aug 04, 2011 | Televison & Video
How to set timer
Switch on a/c by remote.Keep mode and set temp as you need. Now press timer on button. In some unit it follows on clock. and some units it follows time starting. That is if you need to start after one hour you have to press timer still 01.00. Same way to timer off also.
Dec 16, 2010 | Heating & Cooling
Hello I need instructions on setting up the timer using the remote control for a RES 24C1 air conditioning unit. Hope you can help. thanks
There are 2 systems in timer set up. You follow as per your remote supports.
1. Set clock first. and then by pressing timer on make the time you need on. and same for off by timer off.
2. Press timer on which starts with 00.00. By pressing you can select how many hours after you want to switch on from current time and same for timer off. Is it useful? Write.
Dec 11, 2010 | Fujitsu 24C1 Air Conditioner
How do you set on and off mode on air conditioning
Use the remote to enter the timer to switch off - OFF timer setting and the On timing after setting the clock on the remote
Once this is presetted the unit will continue to work shut of in the thermostat settings and fully cuts off power in the set off time.
later the set will come back in the set on time and work till the thermostat setting is reached.
Aug 29, 2010 | LG Heat cool Window Air Conditioner
The microwave will not operate although the timer clock still works
is the door hook broken it sounds like microwave is reacting as if door is always open.
May 19, 2010 | Neff H5642 Convection / Microwave Oven
Have SANYO VCR/DVD Model E175216 and can't locate timer button for late night programming
Hi, if ithere is no button on the front of the unit or on the remote, then simply setting the unit to standby with either power button should make the unit enter the timer record mode. (This will be indicated with TIMER or a small red clock symbol in the display providing all the conditions have ben met. i..e clock & timer correctly set, tape in machine, etc)
Mar 16, 2010 | Sanyo DVW-5000 DVD Player/VCR
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sanyo Microwave Ovens
After pressing the TIME button, the number pad does not react.
A hard reset, that is, removing the unit from the electric source and restarting it after a few seconds, solved the problem.
Apr 05, 2009 | LG LMV1630 Convection/Microwave Oven
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
Amcor PLM-14000E Portable Air Conditioner Logo
14 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
