Question about Dell Inspiron 1525 Notebook
No charge goes to notebook - I think, the inter conector is bad - can be changed ? Thank.
    Sergeant:
  • 261 Answers
First check the light on charger is glowing.there may be problem in converter which converts ac to dcif it is correct then there is other problem in charger.take it to service centre if it is under warranty it can can be changed otherwise first check price in market and then service centre price.
hoping it will help u
thnx
Posted on Jan 04, 2011
New computor,my screen goes blank(blue computor screen)happens ounce in a while for a short time. is this normal, have high speed interent.
When it does this, is it just the display that goes blank or is there a message pn the screen? What version of windows?
Jan 20, 2013 | ASUS Eee 4G Notebook
When powering on the power light goes back out affter about 3 seconds medion akoya model no s5610
I would think that the power supply, if connected, is having some issues and not supplying what it needs to for the notebook. If power supply is not connected, then the battery is defective or needs to be charged (which may not due to bad power supply). Try another supply (perhaps aftermarket universal in the store?) to see if anything changes.
Aug 21, 2011 | Medion md40298 Notebook
Boot up problems, start but will not boot, press power up will not access hd
check the power conector is firmly connected to hdd or change the power conector to another one which is free loose contact in the power wont run the hdd change the ide connector or sata with a new one place ur hand on the hdd and feel wether the hdd is running if not change the power conector still not runnunig change ur hdd to new one also look ide slot in the motherboard and the hdd for bend pin or broken leads
Oct 13, 2010 | Dell Inspiron 6000 Notebook
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
I have a samsung nc10 notebook, when charging the
Hi
The problem you are experiencing is from either the screen of your laptop,the screen board which holds the screen in place or the screen bulb which lights up your screen.
You should get an expert to diagnose which one of the three is faulty, but at least one of the three things i have listed is faulty.
Thank you for visiting fixya
Mar 03, 2010 | Samsung NC10-14GW Notebook
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
Nov 27, 2009 | Acer Aspire 3610 Notebook
Dead DS???
There is a fuse beside the conector for batt, replace this and problem solved
Mar 15, 2008 | Nintendo DS Lite Console
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Dell Inspiron 1525 Notebook Logo
26 people viewed this question
Alun Cox
