Question about Singer 2932 Mechanical Sewing Machine
I have the Singer model 2932. I have threaded and re-threaded the upper thread and the bobbin case... but every time I go to sew it does 1-2 stitches and then jams. I really can't figure out why it is doing this.
  • 323 Answers
SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Posted on Aug 29, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
How to thread a singer sewing machine serial ZHC313405023 Model 1525?
It's possible that you do not have your bobbin or bobbin case in correctly. If you do not have your user's manual (which you should use like your bible), download it free at the Singer website. Review the threading steps for both top and bottom.
One more VERY IMPORTANT thing. On ANY model sewing machine going back to their invention from any company, you MUST thread with the presser foot UP. That is because there are tension disks that apply tension to the upper thread that are ONLY spread apart when the foot is up. If it's down, the thread can't get between them, and there's no tension on the upper thread. That might also be your problem.
Sep 21, 2014 | Singer Sewing Machines
Singer 7463
Check manual for proper threading and insertion/orientation of needle. Or...needle damaged.
Aug 09, 2014 | Singer Confidence 7463 Computerized Sewing...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Whenever I sew the top thread breaks. The machine seems to sew but then jams when I take the material off the top theard is all cut on the underside of the fabric and the bobbin thread is just there. ...
to see if a needle & thread are compatable, take a strand of the thread your going to use & the needle your going to sew with & put the thread thru the eye of the needle & hold it at a 90 degree angle & see if the needle goes down the thread easily
check the needle plate to see if there's any burrs or sharp edges & the bobbin case also
make sure the top thread does not come off the thread take up lever,cause that can make it jam also
it also possible that the machine could be out of time & would need to be serviced at a repair shop
Aug 12, 2011 | Singer 2932 Mechanical Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Singer 2932 Mechanical Sewing Machine Logo
117 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
