Question about Mitsubishi LT-52133 52 in. LCD HDTV
I have a Mitsubishi LT-52133, been setting in the same place for two years and out of the blue the sound quit working. Have unplugged, reset, checked menu, nothing. Static sound emits from speakes when go to DVD 2 where nothing is connected.
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: i have verticle lines on my Mitsubishi LT-52133.
That is not good, it can be as bad the LCD panel is bad which is more likely or the LCD panel inteface board betwwen the screen panel circuit and the main video processor board.
Posted on Nov 03, 2009
budmrtn
  • 11361 Answers
SOURCE: 2 year old Mitsubishi LT-46149 46" LCD Flat Panel
Does it come and go? I would try reseting the ribbon cables between the LCD panel and the T-CON board first.
The Flexible Printed Circuit BoardS (FPCB) are ultrasonic welded to the LCD TFT panel, they are not SOLDERED on! The connections do get bad due to very delicate nature of how the LCD panels are made. You can also try squeezing the around the top area of the screen where the lines are to see if the lines go away.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 15, 2010
  • 301 Answers
SOURCE: i have a 5 inch vertical bar on the right side of
that problem is going to be an LCD panel failure. it is actually a T-CON failure but mitsubishi doesnt sell the T-CON board by itself i suggest calling mitsubishi about possible repair accomodation customer support phone number - 1(800)332-2119 good luck
Posted on Jan 06, 2011
SOURCE: My mitsubishi Model # WD-60737.
i had the same problem and i called mitsubishi they said it is a software malfunction and they are sending me an update to install via flash drive. i am now awaiting the email
Posted on Jan 11, 2011
Can a soundbar an sub woofer be hook to Lt 52133, 07 model. if so how and what product #.
Yes! Use the digital audio output from the Mitsubishi TV to the soundbar! You need a digital audio cable that usually comes with the soundbar!
Dec 30, 2014 | Mitsubishi LT-52148 52 in. LCD HDTV
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
Vertical lines fix
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 08, 2014 | Mitsubishi LT-52133 52 in. LCD HDTV
How do I remove tv stand on my mitsubishi LT 52133
There should be screws or a push button around where it connects to the tv
Jul 22, 2012 | Mitsubishi LT-52133 52 in. LCD HDTV
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
I have a 5 inch vertical bar on the right side of the picture on my mitsubishi lt-52133 tv. tried to reset the tv but it didnt help.....
Jan 06, 2011 | Mitsubishi LT-52133 52 in. LCD HDTV
I have 3 inch band that the color is greenish it only shows up on certain colors.
This could be a defective T-Con board or Digital board. Have it looked at by a professional for exact solution.
Nov 25, 2010 | Mitsubishi LT-52133 52 in. LCD HDTV
I have verticle lines on my Mitsubishi LT-52133. the lines are perfectly up and down and the picture in the middle is good but about 4 inches on the left is dark and miscolored and 4 inches on the left are...
Nov 03, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Yellowing spots on 52 inch LCD Mitsubishi display
have the store fix it you need a tech that has the right equipment to fix that. Since you say you replaced the lamp I assume you mean a LCD micro projector not an LCD Flat panel. There is a piece of equipment that a tech should have that can be plugged into the TVs circuit board and it can fix the spots with an electric pulse. I have seen in done on micro projectors in the store that i work by our techs. So my advise is have the store fix it before your warranty runs out.
Mar 24, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
Mitsubishi LT-52133 52 in. LCD HDTV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
