What is TDS - Computers & Internet
I need a solution for konica 7145 error code 26-3
F26-3: TDS (Toner density sensor output abnormality) Abnormal output from TDS (Toner density sensor) TDS output ripple voltage failed to reach 0.5V
Possible that developer needs to be replaced or Toner is not supplying into the developer Unit.
Service Manual available to your model at: http://fixmfp.com/index.php?route=product/product&path=60&product_id=52
Sep 06, 2013 | Office Equipment & Supplies
My father is NRI and he has saving in fd in banks. Bank is deducting tds for income tax on it, is ti correct?
The interest earned on the fixed deposits is considered as income and bank is required to deduct tds on it. If ur father's total income is less than exemption limit then he can submit form 15h and tds will not be cut. See http://www.makemyreturns.com/income-tax-efiling/nri-taxation-services.aspx for more details on how to avoid tds
Nov 30, 2012 | Cars & Trucks
My RO light has changed from red to green. What does that mean? Red was the normal color.
Green is the color it should be when producing GOOD (low TDS) water. A constant Red light indicates the TDS is high (relative to what the normal TDS rejection is on your water supply) and the membrane needs to be replaced. Frequently the TDS light will be RED when initially drawing water at the RO faucet because of a spike of TDS coming through membrane from static water in line.
I suggest taking a sample of pretreated water and RO water to a dealer for a TDS test to see if the Membrane needs replacing.
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
Procedure to open .tds winzip file version 3.0
You cannot open .tds files with winzip. Check this information: http://filext.com/file-extension/TDS It might be helpful. Good luck.
Jun 18, 2011 | Computers & Internet
What settings should I use for incoming/outgoing server to set up my tds email on my motoblur phone?
ISP Name
TDS Telecom
Country
USA
POP3 Server
(Incoming Mail Server)
popmail.tds.net
SMTP Server
(Outgoing Mail Server)
smtp.tds.net
Dec 21, 2010 | Computers & Internet
Stops will not spin had censor replace still will not spin.
Is the wash tub banging around in Spin Cycle with a wash load then failing with a dC or UC unballance error code?
If so the TDS is working as designed. Try a Spin Only cycle with no clothes in the wash basket. If it completes then the issue is most likely a clutch malfunction of your FAV6800A or FAV9800A machine. See this post Clutch Fix
Did you replace the TDS sensor or did a repair person? If it was a repair person did they try a Wet Load Spin Cycle after the TDS replacement?
If a repair person was called and the TDS replaced what troubleshooting steps did they take to warrant changing out the TDS? I would ask if the range of montion check of the TDS was checked for properation signaling action to the Control Board in Service Mode.
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How do you know if you need to replace the RO membrane filter in the culligan good water machine
A TDS (total dissolved solids)meter is needed to test the Reverse Osmosis water and compare it to the feed water to determine how much TDS is being removed. Reverse osmosis membranes are designed to remove 80-95% of the TDS in your water supply.
For example: If your water has 500ppm of TDS the minimum TDS removal should be 400ppm leaving 100ppm. If the TDS from the Reverse Osmosis System drops to these levels it is time to change the Membrane.
Typically an RO system will consistently remove 90+% of TDS for many years. The normal lifespan for a membrane can be anywhere from 3-10 years. It all depends on the TDS of your water and your water usage. The higher the TDS the more frequently the membrane needs replacing. The other filters should be replaced every 6 months to keep the quality up and protect the membrane.
A TDS of 1000ppm compared to 100ppm is much more difficult remove to acceptable levels. I like to compare 1000TDS to taking muddy water, forcing it through a filter and getting drinking water. Where 100TDS may be more like a clear glass of water. Consequently a reverse osmosis system on high TDS will be less efficient, less gallons produced and filters will need to be changed more frequently to keep the quality and quantity up.
RJ
Oct 04, 2010 | Culligan Under Sink Water Filter
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
Description
P26 or P27 at power up or during copier operation.
Solution
PROBABLE CAUSES:
1. Open connection from the TDS sensor to the main CB or lack of developer. The TDS output is abnormal (0.2V DC or lower).
Verify that the sensor output is above 0.2V DC by monitoring CN6-A9 on the main CB while running the main motor in diagnostics (47 mode, output code 40).
Repair any poor connections to the TDS sensor and supply developer if necessary.
2. Code occurs after resetting the PM counter and P26 occurs if machine is powered OFF/ON, because the L-detect (TDS) adjustment was not performed
Jun 01, 2009 | Konica Minolta Office Equipment & Supplies
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
