Question about AKG K142HD HIGH DEFINITION CLOSEDBACK STUDIOQUALITY HEADPHONES
My K142 HD now works only on the left side. By pushing down on the right side of the headphone the right side becomes active. Once released the sound disappears. This problem started after I dropped them from my desk onto the floor (only a 3 to four feet in height).
Left speaker not working
I don't believe it to be a cable or plug problem, so it sounds like it's a speaker problem. I look up the review of these and it could have some kind of circuit built into each side. If it does it could be that. As they are not cheap headphones by the look of it, perhaps worth repairing. But if the speaker has gone, it might be as much as a new pair.
Jan 03, 2014 | Sennheiser HD 558 Headphones
I have headphones and the left earbud doesn't work,please help!
Ok so it sounds (no pun intended) like either the L speaker itself is blown or the solder connection has become broken for the left side. So you can either try to fix them or if possible replace with a new pair. You can get a very good set of ear buds for for reasonable price at...TJ Max. Yes no joke I bought mine there at they are great and they were only 7.99 but dont let the price fool you, they are of HD quality and brand.
Oct 15, 2013 | Audio Players & Recorders
Left Ear cup not working.
Either ship them back to manufacturer if still under waranty or you'll have to re-solder the wiring to that speaker if they have become disconnected or yanked accidentally of which the leftside is usually where the headphone cable first enters in the left side.
Oct 10, 2013 | Audio Technica ATH-ANC27 Headphones
Where is the signal flasher located
on the indicator stalk left and behind the steering wheel connected ot the steeing column if you push it away if will set the headlights to high beam if you push it towards you fully it will flash the headlamps.
the indictors to signal left and right are also on the left stalk push down for left and up for right.
the hazzard flasher is located in the middle of the dashboad above the radio and is a red triange depress once to activate and once again to deactivate.
if the wiper active at any time then try the stalk on the oposite side of the steering wheel.
Nov 13, 2009 | 2002 Volkswagen Jetta TDI
Headphone jack seemingly screwed up
What generally happens to connectors, especially exposed to air is they oxydize.
Buy a can of "Contact Cleaner" from a local Radio Shack and spray it (through the thin tube usually provided) into the jack. One quick push, dont flood it. Take the earphone jack and insert and remove it several times, wiping off excess, which sould clear contacts and it should work normally again. If not it would have to be replaced which is no easy matter requiring an experienced Technician or Factory. Sometimes it cannot be replaced without damaging the Mother Board. This however sounds like a common problem the Contact Cleaner will fox
Cheers,
Good Luck :)
Sep 04, 2009 | Sony VAIO VGN-FS640W Notebook
No sound in left sennheiser HD600 headphone
It looks like the speaker has gone. Check with your local authorised dealer for a replacement speaker.
Oct 17, 2017 | Sennheiser HD 600 Consumer Headphones
Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
Mar 29, 2009 | Audio Players & Recorders
Sound only come out of one side
take the player apart and take the board out and on the headphone jack there are 3 prongs push them down slightly should work.
Jan 15, 2009 | RCA JET S2002 MP3 Player
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
AKG K142HD HIGH DEFINITION CLOSEDBACK STUDIOQUALITY HEADPHONES Logo
56 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
